10.3 in Mavericks
COW Forums : Square Box CatDV
Robb Harriss
10.3 in Mavericks
on Jun 24, 2015 at 4:17:46 pm
Let me get this straight: CatDV version 10.3 will NOT work in Mavericks and above?
Non-linear: all the time and nothing but.
Robb Harriss
Re: 10.3 in Mavericks
on Jun 24, 2015 at 4:31:10 pm
Ok, that's 10.1.3 pro
Rolf Howarth
on Jun 26, 2015 at 3:18:32 pm
CatDV 10.1.3 should still run in Mavericks (OS X 10.9) but won't work in Yosemite (OS X 10.10) because Apple removed some of the libraries that old versions of CatDV use. Worker Node 5 has the same requirements by the way, and will also not work in Yosemite.
Instead, for use on Yosmite you need CatDV 11 (and Worker 6) which use a completely different new architecture and run as 64-bit processes, with a separate native helper process to provide media processing capabilities.
-Rolf
Robb Harriss
on Jun 26, 2015 at 3:46:54 pm
Thanks for the explanation of why the older version won't work on Yosemite. I hadn't heard it before. Generally it's the other way around, where software won't run on older versions of the OS. This time it's more like the demise of the PowerPC.
