Worker catalog publish into Group/folder
COW Forums : Square Box CatDV
John Heagy
on May 18, 2015 at 8:09:28 pm
Is there a way of specifying Production Group and folder name in Worker's "Publish to server"? I want Worker to create catalogs in a certain folder within a Production Group. Group_name/folder_name doesn't do it in the Group field.
Same question when publishing a local catalog to server. Is there a way to prefix the folder name when naming the catalog so it gets saved into a folder?
John
bryson jones
Re: Worker catalog publish into Group/folder
on May 18, 2015 at 9:10:14 pm
In the "publish" tab of Worker you can specify the Group. (Not the folder!)
The "Folder" is just a function of the name, although with the "/" in that name I'm not sure that it would work. Maybe try escaping the slash?
bryson
bryson "at" northshoreautomation.com
John Heagy
on May 18, 2015 at 10:12:33 pm
Hi Bryson,
Thanks for the response.
I'm having Worker create a daily restored file catalog.
How do you keep Worker created catalogs from spamming the main Production Group? Do you create a Group specifically for Worker created catalogs?
bryson jones
on May 18, 2015 at 10:38:15 pm
Oh yeah, that. ;)
Yes, I tend to hide them when I can.
bryson
John Heagy
on May 19, 2015 at 9:42:06 pm
Putting the folder name then a / before the catalog name in the Catalog name field did direct the catalog to the folder. I was doing it in the Group field.
