Preserve Metadata from PremierePro Capture to CatDV
COW Forums : Square Box CatDV
Lindsay Simpson
on Apr 20, 2015 at 11:56:15 pm
I am in the process of digitizing and cataloging a large library of video on tape. Metadata entered into the "log note" field in the Project panel of Premiere Pro CC 2014 is saved and imported with a clip ingested into CatDV. However, the "log note" field in the Capture panel of Premiere Pro does not translate, or import, with the clip into CatDV. In fact of the 6 user-editable metadata fields in the Capture panel, only the "tape name" field carries over upon ingest into CatDV.
I would like to be able to include a clip description as part of this capture process to maximize efficiency. Is there any means to do this using Premiere Pro to capture?
Alternate suggestions to achieve the same end?
Thanks for your time and thoughts!
Leonard Estupiñan
Re: Preserve Metadata from PremierePro Capture to CatDV
on May 19, 2015 at 9:31:16 pm
Hi, Lindsay my name is Leonard Estupiñan i am from to Ecuador southamerica, i work in Ecuador Television Public and my tool is a Ikegamy HDS-V10 but i don t have the manual operation, i need it? Do you have it? plz, sorry my engish is very bad :-D
