Same field name (but duplicated) = same query results?
COW Forums : Square Box CatDV
Carla Vidal
on Apr 1, 2015 at 12:26:27 pm
Hi there,
It might be a stupid question but I would like to make sure of this issue.
I have a NOTES (red) user defined field which we have been using so far.
I realised that there is a built in field also named NOTES (green). I have been changing things in both detailed panel and search panel and now I am worried if I changed from one NOTES green to the other NOTES red -or viceversa- and that implies not getting all the results because the program understands it as two different fields...
Thank you in advance for helping
Cheers
Carla
Dougal Matthews
Re: Same field name (but duplicated) = same query results?
on Apr 15, 2015 at 10:31:51 am
hi Carla
you can use the Bult edit tool to append the contents of one field to another i suggest in your case you move the contents of your user created ( red ) notes field to the built in ( green) notes field
if you use the append option you will add the red notes to any existing green notes
Use Bulk Edit as a flexible tool to copy one field to another or automatically renumber clips. Select the destination field whose value you want to set, then either type in a fixed value to use or select another property to copy or move to the destination. To use automatic numbering type in a value like “Scene 009″ and the next line will automatically be incremented to “Scene 010″ etc.
thank you dougal
Improvise Adapt and Overcome
Carla Vidal
on Apr 15, 2015 at 3:20:29 pm
Yes I know the bulk edit tool, thank you for the detailed explanation. It's been very useful since I didn't think about it to solve the problem. Thanks!
