Web2 client
COW Forums : Square Box CatDV
Henrik Helms
Web2 client
on Feb 20, 2015 at 1:50:42 pm
Hi!
I have upgraded my server to 6.10 and wanted to access the web2 client - but I can't find anything in the documentation on what web-adress to use in my browser to get to the web2 client.
It only says ...navigate to the web2 client and login...
Perhaps its me going blind...:-)
Greetings
Henrik Helms
dBA MEDIA
John Vaudin
Re: Web2 client
on Feb 20, 2015 at 2:23:08 pm
Assuming you are using the built-in web server on the default port then navigating to:
http://localhost:8080
should take you to the CatDV Server home page. There are links on there to the current Web Client and CatDV Web 2.
If you need the direct link (for example if you are using Tomcat) then it is:
http://localhost:8080/catdv-web2
Henrik Helms
Re: Web2 client
on Feb 20, 2015 at 2:40:22 pm
Thanks John!
That worked!
Greetings
Henrik Helms
dBA MEDIA
