Anyone able to get HandbrakeCLI working with Worker?
COW Forums : Square Box CatDV
Shane French
on Jan 2, 2015 at 8:19:53 am
Has anyone had success getting HandbrakeCLI (the command line version) working with Worker?
I've been trying to get it working with not much luck. It actually encodes the video fine, but the last result shown in worker is: libhb: work result = 0
That's normal...and in fact Handbrake has done the encoding. But it's as if Worker doesn't know that it's done, and Worker just reports Running...
Of course, running HandbrakeCLI on it's own with the same files works fine.
Shane
bryson jones
Re: Anyone able to get HandbrakeCLI working with Worker?
on Jan 3, 2015 at 12:55:30 am
Shane, if something is having issues "telling" the Worker that it's done, we often put the command into a small shell script and have Worker fire that.
That way you can separate the two and avoid conflicts.
bryson
bryson "at" northshoreautomation.com
Shane French
on Jan 3, 2015 at 7:33:54 pm
Good idea - I'll give that a try. Thanks!
