replaceSettings Failed (Packet for query is too large)
COW Forums : Square Box CatDV
Shane Johnson
on Aug 13, 2014 at 9:45:35 pm
I got an error today when trying to update the Details Panel (adding and removing a field). I've never seen this before and am unsure where (or if I SHOULD) update the variable settings. Anybody know how to fix this?
replaceSettings Failed (Packet for query is too large (1196974 > 1048576). You can change the value on the server by setting the max_allowed_packet' variable.)
John Vaudin
Re: replaceSettings Failed (Packet for query is too large)
on Aug 14, 2014 at 8:37:41 am
It's not uncommon to need to increase max_allowed_packet in you my.conf or my.ini file. I ususally set it to 16M.
Shane Johnson
on Aug 14, 2014 at 3:27:17 pm
Hmm, I'm not sure where to find either of those files and I did a search on the whole server.
Where do I find those files?
bryson jones
on Aug 14, 2014 at 10:50:39 pm
I have the info Shane, trying to get a quick way to share it to the world.
That's a MySQL admin thing and you may want your integrator to do it, but I'll post the steps as soon as I can. (we're doing a web re-work.)
bryson
bryson "at" northshoreautomation.com
John Vaudin
on Aug 15, 2014 at 9:20:41 am
Sorry - finger trouble - I of course meant my.cnf (on a Mac). Its location can vary but its usually /etc/my.cnf.
bryson jones
on Aug 15, 2014 at 5:20:57 pm
Hey guys, this is a quick doc we keep in our internal wiki for our field techs.
I'm posting it publicly with the hope that if it helps you, you take a look at Akomi as payback. ;)
Catdv-Server MySql max_allowed_packet setting
bryson
Shane Johnson
on Aug 15, 2014 at 6:08:03 pm
Squarebox actually logged into our server and the reason I couldn't find that setting was because they needed to ADD the line into one of the files... Not sure how it went missing, but it is fixed now.
Thanks a ton for your help!
bryson jones
on Aug 15, 2014 at 7:01:06 pm
I do need to add that one.
Often it's not in there but you can just add the line. As I understand it, as long as the doc looks similar to the example shown you're good.
bryson
