Worker Node fails sending email
COW Forums : Square Box CatDV
Shane Johnson
on Jun 30, 2014 at 3:50:57 pm
Right now I am using a variable to send to an email address ${UnixUser}@XXXXXXXXX.com
This works correctly on our windows server, but not on the Mac server that we use to convert videos. The smtp configuration works correctly when testing, but any job that does the conversion fails when it tries the post-processing step of sending the email.
Log:
[1;15:47:54.131] CatDV Worker Node 5.1.0 starting 2014-06-26 15:47:54
[1;15:47:54.167] apple.awt.brushMetalLook = false
[1;15:47:54.168] apple.awt.showGrowBox = false
[1;15:47:54.168] apple.laf.useScreenMenuBar = true
[1;15:47:54.168] awt.nativeDoubleBuffering = true
[1;15:47:54.168] awt.toolkit = apple.awt.CToolkit
[1;15:47:54.168] catdv.mainClass = squarebox.catdv.worker.WorkerMain
[1;15:47:54.168] file.encoding = MacRoman
[1;15:47:54.168] file.encoding.pkg = sun.io
[1;15:47:54.168] file.separator = /
[1;15:47:54.168] ftp.nonProxyHosts = local|*.local|169.254/16|*.169.254/16
[1;15:47:54.168] gopherProxySet = false
[1;15:47:54.168] http.nonProxyHosts = local|*.local|169.254/16|*.169.254/16
[1;15:47:54.168] java.awt.graphicsenv = apple.awt.CGraphicsEnvironment
[1;15:47:54.168] java.awt.printerjob = apple.awt.CPrinterJob
[1;15:47:54.168] java.class.path = /Applications/CatDV Worker 5.1.0/CatDV Worker.app/Contents/Resources/Java/worker.jar:/Applications/CatDV Worker 5.1.0/CatDV Worker.app/Contents/Resources/Java/xalan.jar:/Applications/CatDV Worker 5.1.0/CatDV Worker.app/Contents/Resources/Java/crimson.jar:/Applications/CatDV Worker 5.1.0/CatDV Worker.app/Contents/Resources/Java/jakarta-regexp-1.5.jar:/Applications/CatDV Worker 5.1.0/CatDV Worker.app/Contents/Resources/Java/jakarta-poi-1.10.0-dev.jar:/Applications/CatDV Worker 5.1.0/CatDV Worker.app/Contents/Resources/Java/mail.jar:/Applications/CatDV Worker 5.1.0/CatDV Worker.app/Contents/Resources/Java/activation.jar:/Applications/CatDV Worker 5.1.0/CatDV Worker.app/Contents/Resources/Java/jmf.jar:/Applications/CatDV Worker 5.1.0/CatDV Worker.app/Contents/Resources/Java/fobs4jmf.jar:/usr/local/xuggler/share/java/jars/xuggle-xuggler.jar
[1;15:47:54.168] java.class.version = 50.0
[1;15:47:54.168] java.endorsed.dirs = /System/Library/Java/JavaVirtualMachines/1.6.0.jdk/Contents/Home/lib/endorsed
[1;15:47:54.168] java.ext.dirs = /Library/Java/Extensions:/System/Library/Java/Extensions:/System/Library/Java/JavaVirtualMachines/1.6.0.jdk/Contents/Home/lib/ext
[1;15:47:54.169] java.home = /System/Library/Java/JavaVirtualMachines/1.6.0.jdk/Contents/Home
[1;15:47:54.169] java.io.tmpdir = /var/folders/I-/I-Md6ugLHAKy9ONTvQhk5++++TQ/-Tmp-/
[1;15:47:54.169] java.library.path = /Applications/CatDV Worker 5.1.0/CatDV Worker.app/Contents/Resources/Java:/usr/local/xuggler/lib:/System/Library/PrivateFrameworks/JavaApplicationLauncher.framework/Resources
[1;15:47:54.169] java.runtime.name = Java(TM) SE Runtime Environment
[1;15:47:54.169] java.runtime.version = 1.6.0_65-b14-462-10M4609
[1;15:47:54.169] java.specification.name = Java Platform API Specification
[1;15:47:54.169] java.specification.vendor = Sun Microsystems Inc.
[1;15:47:54.169] java.specification.version = 1.6
[1;15:47:54.169] java.vendor = Apple Inc.
[1;15:47:54.169] java.vendor.url = <a href='http://www.apple.com/'>http://www.apple.com/</a>
[1;15:47:54.169] java.vendor.url.bug = <a href='http://bugreport.apple.com/'>http://bugreport.apple.com/</a>
[1;15:47:54.169] java.version = 1.6.0_65
[1;15:47:54.169] java.vm.info = mixed mode
[1;15:47:54.169] java.vm.name = Java HotSpot(TM) Client VM
[1;15:47:54.169] java.vm.specification.name = Java Virtual Machine Specification
[1;15:47:54.169] java.vm.specification.vendor = Sun Microsystems Inc.
[1;15:47:54.169] java.vm.specification.version = 1.0
[1;15:47:54.169] java.vm.vendor = Apple Inc.
[1;15:47:54.170] java.vm.version = 20.65-b04-462
[1;15:47:54.170] line.separator =
[1;15:47:54.170] mrj.build = 10M4609
[1;15:47:54.170] mrj.version = 1060.1.6.0_65-462
[1;15:47:54.170] os.arch = i386
[1;15:47:54.170] os.name = Mac OS X
[1;15:47:54.170] os.version = 10.6.8
[1;15:47:54.170] path.separator = :
[1;15:47:54.170] socksNonProxyHosts = local|*.local|169.254/16|*.169.254/16
[1;15:47:54.170] sun.arch.data.model = 32
[1;15:47:54.170] sun.boot.class.path = /System/Library/Java/JavaVirtualMachines/1.6.0.jdk/Contents/Classes/jsfd.jar:/System/Library/Java/JavaVirtualMachines/1.6.0.jdk/Contents/Classes/classes.jar:/System/Library/Frameworks/JavaVM.framework/Frameworks/JavaRuntimeSupport.framework/Resources/Java/JavaRuntimeSupport.jar:/System/Library/Java/JavaVirtualMachines/1.6.0.jdk/Contents/Classes/ui.jar:/System/Library/Java/JavaVirtualMachines/1.6.0.jdk/Contents/Classes/laf.jar:/System/Library/Java/JavaVirtualMachines/1.6.0.jdk/Contents/Classes/sunrsasign.jar:/System/Library/Java/JavaVirtualMachines/1.6.0.jdk/Contents/Classes/jsse.jar:/System/Library/Java/JavaVirtualMachines/1.6.0.jdk/Contents/Classes/jce.jar:/System/Library/Java/JavaVirtualMachines/1.6.0.jdk/Contents/Classes/charsets.jar:/System/Library/PrivateFrameworks/JavaApplicationLauncher.framework/Resources/LauncherSupport.jar
[1;15:47:54.170] sun.boot.library.path = /System/Library/Java/JavaVirtualMachines/1.6.0.jdk/Contents/Libraries
[1;15:47:54.170] sun.cpu.endian = little
[1;15:47:54.170] sun.cpu.isalist =
[1;15:47:54.170] sun.io.unicode.encoding = UnicodeLittle
[1;15:47:54.170] sun.jnu.encoding = MacRoman
[1;15:47:54.170] sun.management.compiler = HotSpot Client Compiler
[1;15:47:54.170] sun.os.patch.level = unknown
[1;15:47:54.171] user.country = US
[1;15:47:54.171] user.dir = /Applications/CatDV Worker 5.1.0
[1;15:47:54.171] user.home = /Users/ingest
[1;15:47:54.171] user.language = en
[1;15:47:54.171] user.name = ingest
[1;15:47:54.171] user.timezone = America/Denver
[1;15:47:54.172] Apple_PubSub_Socket_Render := /tmp/launch-EiVwKt/Render
[1;15:47:54.172] COMMAND_MODE := unix2003
[1;15:47:54.172] DISPLAY := /tmp/launch-hQNQ8F/org.x:0
[1;15:47:54.172] DYLD_LIBRARY_PATH := /usr/local/xuggler/lib
[1;15:47:54.172] HOME := /Users/ingest
[1;15:47:54.172] JAVA_LIBRARY_PATH := /Applications/CatDV Worker 5.1.0/CatDV Worker.app/Contents/Resources/Java:/System/Library/PrivateFrameworks/JavaApplicationLauncher.framework/Resources
[1;15:47:54.172] LOGNAME := ingest
[1;15:47:54.172] PATH := /usr/bin:/bin:/usr/local/xuggler/bin:/usr/local/bin
[1;15:47:54.172] SHELL := /bin/bash
[1;15:47:54.172] SSH_AUTH_SOCK := /tmp/launch-zlV6xd/Listeners
[1;15:47:54.172] TMPDIR := /var/folders/I-/I-Md6ugLHAKy9ONTvQhk5++++TQ/-Tmp-/
[1;15:47:54.172] USER := ingest
[1;15:47:54.172] XUGGLE_HOME := /usr/local/xuggler
[1;15:47:54.172] __CF_USER_TEXT_ENCODING := 0x1F7:0:0
[1;15:47:54.172] com.apple.java.jvmTask := BundledApp
[1;15:47:54.175] com.sun.xml.parser.SAXParserFactoryImpl
[1;15:47:54.175] Failed to secure load com/sun/xml/parser/SAXParserFactoryImpl
[1;15:47:54.175] java.lang.ClassNotFoundException: com/sun/xml/parser/SAXParserFactoryImpl
[1;15:47:54.175] org.apache.crimson.jaxp.SAXParserFactoryImpl
[1;15:47:54.177] got org.apache.crimson.jaxp.SAXParserFactoryImpl@cbf30e
[1;15:47:54.206] ** Instantiating MFDelegate ***
[1;15:47:54.325] squarebox.catdv.mf.QTDelegate@1aa9f99
[1;15:47:54.327] Failed to secure load com/sun/xml/parser/SAXParserFactoryImpl
[1;15:47:54.334] Failed to secure load com/sun/xml/parser/SAXParserFactoryImpl
[1;15:47:54.335] Failed to secure load com/sun/xml/parser/SAXParserFactoryImpl
[1;15:47:54.336] Failed to secure load com/sun/xml/parser/SAXParserFactoryImpl
[1;15:47:54.337] Failed to secure load com/sun/xml/parser/SAXParserFactoryImpl
[1;15:47:54.338] Failed to secure load com/sun/xml/parser/SAXParserFactoryImpl
[1;15:47:54.338] load format BB Proxy (QuickTime)
[1;15:47:54.339] load format MP4 Conversion (QuickTime)
[1;15:47:54.352] got 2 formats
[1;15:47:55.430] getTitledBorderTextColor = java.awt.Color[r=51,g=153,b=224]
[1;15:47:55.740] Status: Initialising...
[1;15:47:55.741] <?xml version='1.0' encoding='UTF-8' standalone='yes'?>
[1;15:47:55.741]
[1;15:47:55.741]
[1;15:47:55.741]
[1;15:47:55.742]
[1;15:47:55.742]
[1;15:47:55.742]
[1;15:47:55.742]
[1;15:47:55.742]
[1;15:47:55.742]
[1;15:47:55.742]
[1;15:47:55.742]
[1;15:47:55.742]
[1;15:47:55.742]
[1;15:47:55.742]
[1;15:47:55.742]
[1;15:47:55.742]
[1;15:47:55.742]
[1;15:47:55.742]
[1;15:47:55.742]
[1;15:47:55.742]
[1;15:47:55.742]
[1;15:47:55.743]
[1;15:47:55.743]
[1;15:47:55.743]
[1;15:47:55.743]
[1;15:47:55.743]
[1;15:47:55.743]
[1;15:47:55.743]
[1;15:47:55.743]
[1;15:47:55.743]
[1;15:47:55.743]
[1;15:47:55.743]
[1;15:47:55.743]
[1;15:47:55.743]
[1;15:47:55.744]
[1;15:47:55.744]
[1;15:47:55.744]
[1;15:47:55.744]
[1;15:47:55.744]
[1;15:47:55.744]
[1;15:47:55.744]
[1;15:47:55.744]
[1;15:47:55.744]
[1;15:47:55.744]
[1;15:47:55.744]
[1;15:47:55.744]
[1;15:47:55.744]
[1;15:47:55.744]
[1;15:47:55.744]
[1;15:47:55.744]
[1;15:47:55.744]
[1;15:47:55.744]
[1;15:47:55.745] Failed to secure load com/sun/xml/parser/SAXParserFactoryImpl
[1;15:47:55.746] load format BB Proxy (QuickTime)
[1;15:47:55.746] load format MP4 Conversion (QuickTime)
[1;15:47:55.748] got 2 formats
[1;15:47:55.793] Resetting server connections...
[1;15:47:55.809] Not loading language file in worker
[1;15:47:55.811] Perform remote: Connect
[1;15:47:55.811] connect Command Line Helper@ingeststation.body.local(null) code=MZX6-XTHM-W9FC-56NI-JW4K-UVNA-V2Z1-1U7O
[1;15:47:58.054] *** Naming.lookup rmi://catdv.body.local/CatDVServer -> CatDVServer_Stub[UnicastRef [liveRef: [endpoint:[10.7.70.53:1099](remote),objID:[38ddffa6:14423678478:-7fff, 2446321902347308753]]]] took too long ***
[1;15:47:58.131] Perform remote: Get Property
[1;15:47:58.132] Connected to CatDV server version 6.7b10-1632 on ingeststation.body.local as Command Line Helper@ingeststation.body.local (10.7.30.57)
[1;15:47:58.132] Perform remote: Get Property
[1;15:47:58.134] Perform remote: Get Property
[1;15:47:58.135] Perform remote: Get Property
[1;15:47:58.136] Perform remote: Get Property
[1;15:47:58.137] Perform remote: Get Property
[1;15:47:58.138] Perform remote: Get Property
[1;15:47:58.139] Perform remote: Get Property
[1;15:47:58.140] Perform remote: Get Property
[1;15:47:58.142] Perform remote: Get Property
[1;15:47:58.143] Perform remote: Get Property
[1;15:47:58.144] Perform remote: Get Property
[1;15:47:58.145] Perform remote: Get Property
[1;15:47:58.146] Perform remote: Get Property
[1;15:47:58.147] Perform remote: Get Property
[1;15:47:58.149] Perform remote: Get Property
[1;15:47:58.150] Perform remote: Get Property
[1;15:47:58.151] Perform remote: Get Property
[1;15:47:58.152] Perform remote: Get Property
[1;15:47:58.154] allowAnonymous false
[1;15:47:58.156] Disconnect from server
[1;15:47:58.163] Starting ingeststation.body.local-20140626-154758-0 on /Users/ingest/Library/Application Support/workset.xml at 26/6/2014 3:47:58pm
[1;15:47:58.167] Failed to secure load com/sun/xml/parser/SAXParserFactoryImpl
[1;15:47:58.191] Loaded 40 initial tasks from /Users/ingest/Library/Application Support/workset.xml
[1;15:47:58.372] Initialise workset /Users/ingest/Library/Application Support/workset.xml
[1;15:47:58.372] Perform remote: Connect
[1;15:47:58.372] connect CatDV Worker Node@ingeststation.body.local(null) code=MZX6-XTHM-W9FC-56NI-JW4K-UVNA-V2Z1-1U7O
[1;15:47:58.386] Perform remote: Get Property
[1;15:47:58.388] Connected to CatDV server version 6.7b10-1632 on ingeststation.body.local as CatDV Worker Node@ingeststation.body.local (10.7.30.57)
[1;15:47:58.388] Perform remote: Get Property
[1;15:47:58.389] Perform remote: Get Property
[1;15:47:58.390] Perform remote: Get Property
[1;15:47:58.391] Perform remote: Get Property
[1;15:47:58.392] Perform remote: Get Property
[1;15:47:58.394] Perform remote: Get Property
[1;15:47:58.395] Perform remote: Get Property
[1;15:47:58.396] Perform remote: Get Property
[1;15:47:58.397] Perform remote: Get Property
[1;15:47:58.398] Perform remote: Get Property
[1;15:47:58.399] Perform remote: Get Property
[1;15:47:58.400] Perform remote: Get Property
[1;15:47:58.401] Perform remote: Get Property
[1;15:47:58.402] Perform remote: Get Property
[1;15:47:58.403] Perform remote: Get Property
[1;15:47:58.404] Perform remote: Get Property
[1;15:47:58.405] Perform remote: Get Property
[1;15:47:58.406] Perform remote: Get Property
[1;15:47:58.407] allowAnonymous false
[1;15:47:58.408] Perform remote: Get Groups
[1;15:47:58.412] Perform remote: LogOn
[1;15:47:58.425] Failed to secure load com/sun/xml/parser/SAXParserFactoryImpl
[1;15:47:58.425] Default group not defined
[1;15:47:58.425] Perform remote: Get Settings
[1;15:47:58.468] Got 90081 bytes in 43ms
[1;15:47:58.476] getSettings took 51ms
[1;15:47:58.476] Failed to secure load com/sun/xml/parser/SAXParserFactoryImpl
[1;15:47:58.476] class org.apache.crimson.jaxp.SAXParserFactoryImpl
[1;15:47:58.476] class org.apache.crimson.jaxp.SAXParserImpl
[1;15:47:58.533] created SourceMedia['null',start=0:00:00.0,end=null,video=(Various),audio=(Various),still=false,thumbnails=0,smedia=null]@1b2b450
[1;15:47:58.535] NAME1=Project Name
[1;15:47:58.535] LOCKED1=false
[1;15:47:58.535] MANDATORY1=true
[1;15:47:58.535] TYPE1=1
[1;15:47:58.535] GROUP1=true
[1;15:47:58.535] NAME2=Episode
[1;15:47:58.535] LOCKED2=false
[1;15:47:58.535] MANDATORY2=false
[1;15:47:58.535] TYPE2=1
[1;15:47:58.535] GROUP2=true
[1;15:47:58.536] NAME3=Talent
[1;15:47:58.536] LOCKED3=false
[1;15:47:58.536] MANDATORY3=false
[1;15:47:58.536] TYPE3=0
[1;15:47:58.536] GROUP3=false
[1;15:47:58.536] NAME4=BB Archive Tape
[1;15:47:58.536] LOCKED4=false
[1;15:47:58.536] MANDATORY4=false
[1;15:47:58.536] TYPE4=0
[1;15:47:58.536] GROUP4=false
[1;15:47:58.536] NAME5=Category
[1;15:47:58.536] LOCKED5=false
[1;15:47:58.536] MANDATORY5=true
[1;15:47:58.536] TYPE5=1
[1;15:47:58.536] GROUP5=true
[1;15:47:58.536] NAME6=Segment
[1;15:47:58.536] LOCKED6=false
[1;15:47:58.536] MANDATORY6=false
[1;15:47:58.536] TYPE6=1
[1;15:47:58.536] GROUP6=true
[1;15:47:58.536] NAME7=Take
[1;15:47:58.537] LOCKED7=false
[1;15:47:58.537] MANDATORY7=false
[1;15:47:58.537] TYPE7=13
[1;15:47:58.537] GROUP7=false
[1;15:47:58.537] NAME8=Angle
[1;15:47:58.537] LOCKED8=false
[1;15:47:58.537] MANDATORY8=false
[1;15:47:58.537] TYPE8=13
[1;15:47:58.537] GROUP8=false
[1;15:47:58.537] NAME9=Location
[1;15:47:58.537] LOCKED9=false
[1;15:47:58.537] MANDATORY9=false
[1;15:47:58.537] TYPE9=0
[1;15:47:58.537] GROUP9=false
[1;15:47:58.537] NAME10=Take Rating: BEST: GOOD: BAD
[1;15:47:58.537] LOCKED10=false
[1;15:47:58.537] MANDATORY10=false
[1;15:47:58.537] TYPE10=13
[1;15:47:58.537] GROUP10=false
[1;15:47:58.537] NAME11=Music Genre
[1;15:47:58.537] LOCKED11=false
[1;15:47:58.538] MANDATORY11=false
[1;15:47:58.538] TYPE11=2
[1;15:47:58.538] MULTI11=true
[1;15:47:58.538] NAME12=Approval Status
[1;15:47:58.538] LOCKED12=true
[1;15:47:58.538] MANDATORY12=false
[1;15:47:58.538] TYPE12=1
[1;15:47:58.538] GROUP12=true
[1;15:47:58.538] NAME13=Archive Status
[1;15:47:58.538] LOCKED13=false
[1;15:47:58.538] MANDATORY13=false
[1;15:47:58.538] TYPE13=1
[1;15:47:58.538] GROUP13=true
[1;15:47:58.538] NAME14=Review Notes
[1;15:47:58.538] LOCKED14=false
[1;15:47:58.538] MANDATORY14=false
[1;15:47:58.538] TYPE14=0
[1;15:47:58.538] GROUP14=false
[1;15:47:58.538] NAME15=Proxy Status
[1;15:47:58.538] LOCKED15=false
[1;15:47:58.538] MANDATORY15=false
[1;15:47:58.538] TYPE15=1
[1;15:47:58.538] GROUP15=true
[1;15:47:58.539] NAME16=Original Catalog
[1;15:47:58.539] LOCKED16=false
[1;15:47:58.539] MANDATORY16=false
[1;15:47:58.539] TYPE16=0
[1;15:47:58.539] GROUP16=false
[1;15:47:58.539] NAME17=Content
[1;15:47:58.539] LOCKED17=false
[1;15:47:58.539] MANDATORY17=false
[1;15:47:58.539] TYPE17=1
[1;15:47:58.539] GROUP17=true
[1;15:47:58.539] NAME18=Keyphrase(s)
[1;15:47:58.539] LOCKED18=false
[1;15:47:58.539] MANDATORY18=true
[1;15:47:58.539] TYPE18=0
[1;15:47:58.539] GROUP18=false
[1;15:47:58.539] NAME19=Restored
[1;15:47:58.539] LOCKED19=false
[1;15:47:58.539] MANDATORY19=false
[1;15:47:58.539] TYPE19=9
[1;15:47:58.539] GROUP19=true
[1;15:47:58.539] NAME20=Test Approval: None :Ready for Review :Final Review :Approve
[1;15:47:58.539] LOCKED20=false
[1;15:47:58.539] MANDATORY20=false
[1;15:47:58.540] TYPE20=11
[1;15:47:58.540] GROUP20=true
[1;15:47:58.540] NAME21=User 21
[1;15:47:58.540] LOCKED21=false
[1;15:47:58.540] MANDATORY21=false
[1;15:47:58.540] TYPE21=0
[1;15:47:58.540] GROUP21=false
[1;15:47:58.540] NAME22=User 22
[1;15:47:58.540] LOCKED22=false
[1;15:47:58.540] MANDATORY22=false
[1;15:47:58.540] TYPE22=0
[1;15:47:58.540] GROUP22=false
[1;15:47:58.540] setNumUserAttributes 22
[66;15:47:58.640] Adding Thread[WorkerThread-1,5,main] tid=66
[1;15:47:58.641] Initialise server watcher 'Make Proxy' : Server Query «Proxy Status 'Make Proxy'»
[1;15:47:58.642] Initialise server watcher 'Ready for YouTube' : Server Query «Status 'Approved' ...»
[67;15:47:58.642] Adding Thread[ServerWatcher-1,5,main] tid=67
[1;15:47:58.643] Initialise server watcher 'Move to YouTube Catalog' : Server Query «Status 'Move to YouTube' ...»
[68;15:47:58.643] Adding Thread[ServerWatcher-2,5,main] tid=68
[1;15:47:58.643] Initialise server watcher 'Approved for YouTube' : Server Query «Status 'Approved for YouTube' ...»
[69;15:47:58.643] Adding Thread[ServerWatcher-3,5,main] tid=69
[70;15:47:58.643] Adding Thread[ServerWatcher-4,5,main] tid=70
[66;15:48:02.640] Starting worker thread 0 on /Users/ingest/Library/Application Support/workset.xml
[66;15:48:03.242] Found 0 complete batch(es)
[66;15:48:03.242] Start next task 0
[67;15:48:11.147]
[67;15:48:11.147] Perform remote: Perform Query
[67;15:48:11.190] Job 'Make Proxy': got 0 clip(s), 0 media(s)
[69;15:48:11.190]
[67;15:48:11.190] Skipped 0 of 0 clips (already added to list, offline, wrong type, etc.)
[69;15:48:11.190] Perform remote: Perform Query
[12;15:48:11.390] Removing old Batch[id=3449,status=3,file=null,numTasks=1,numComplete=1,numSuccess=1]
[12;15:48:11.422] All change
[66;15:48:11.672] Found 0 complete batch(es)
[69;15:48:13.195] Job 'Move to YouTube Catalog': got 0 clip(s), 0 media(s)
[68;15:48:13.196]
[69;15:48:13.196] Skipped 0 of 0 clips (already added to list, offline, wrong type, etc.)
[68;15:48:13.196] Perform remote: Perform Query
[68;15:48:15.049] Job 'Ready for YouTube': got 1 clip(s), 1 media(s)
[70;15:48:15.049]
[70;15:48:15.049] Perform remote: Perform Query
[68;15:48:15.051] adding SClip[ID=1736237.9,name=RIG FOR PAIN FINAL.mov,tape=,type=Movie,inFrame=240,outFrame=13603,tcFmt=2398,catalogID=1655797,userID=1116552,importSourceID=1736236,sourceMediaID=1736227,posterID=1736231] /Volumes/Worker2/Video Articles/Ashley Horner Total Body/EXPORTS/RIG FOR PAIN FINAL.mov
[68;15:48:15.051] Skipped 0 of 1 clips (already added to list, offline, wrong type, etc.)
[68;15:48:15.052] Query took 3900ms to find 1 clip(s)
[68;15:48:15.052] Added 0 tasks
[12;15:48:15.585] Resubmit Task 2107 '/T_Klausen_Photo Graphic 1.mov' with latest job defn 'Ready for YouTube'
[12;15:48:15.606] All change
[66;15:48:15.878] Found 0 complete batch(es)
[66;15:48:15.879] Start next task Task 2107 '/T_Klausen_Photo Graphic 1.mov'
[66;15:48:15.879]
[66;15:48:15.898] All change
[66;15:48:15.899] Updated Batch[id=3448,status=3,file=null,numTasks=1,numComplete=0,numSuccess=0]
[66;15:48:15.900] Performing task on main thread
[66;15:48:15.900] Status: Starting Task 2107 '/T_Klausen_Photo Graphic 1.mov' ...
[66;15:48:15.902] Status: Starting remote helper 1 ...
[66;15:48:15.902] 0: /System/Library/Java/JavaVirtualMachines/1.6.0.jdk/Contents/Home/bin/java
[66;15:48:15.902] 1: -cp
[66;15:48:15.902] 2: /Applications/CatDV Worker 5.1.0/CatDV Worker.app/Contents/Resources/Java/worker.jar:/Applications/CatDV Worker 5.1.0/CatDV Worker.app/Contents/Resources/Java/xalan.jar:/Applications/CatDV Worker 5.1.0/CatDV Worker.app/Contents/Resources/Java/crimson.jar:/Applications/CatDV Worker 5.1.0/CatDV Worker.app/Contents/Resources/Java/jakarta-regexp-1.5.jar:/Applications/CatDV Worker 5.1.0/CatDV Worker.app/Contents/Resources/Java/jakarta-poi-1.10.0-dev.jar:/Applications/CatDV Worker 5.1.0/CatDV Worker.app/Contents/Resources/Java/mail.jar:/Applications/CatDV Worker 5.1.0/CatDV Worker.app/Contents/Resources/Java/activation.jar:/Applications/CatDV Worker 5.1.0/CatDV Worker.app/Contents/Resources/Java/jmf.jar:/Applications/CatDV Worker 5.1.0/CatDV Worker.app/Contents/Resources/Java/fobs4jmf.jar:/usr/local/xuggler/share/java/jars/xuggle-xuggler.jar
[66;15:48:15.902] 3: -d32
[66;15:48:15.902] 4: -Djava.awt.headless=true
[66;15:48:15.902] 5: -Djava.library.path=/Applications/CatDV Worker 5.1.0/CatDV Worker.app/Contents/Resources/Java:/usr/local/xuggler/lib:/System/Library/PrivateFrameworks/JavaApplicationLauncher.framework/Resources
[66;15:48:15.902] 6: -Xdock:name=Worker Helper 1
[66;15:48:15.902] 7: -Xmx512m
[66;15:48:15.903] 8: -Dfile.encoding=MacRoman
[66;15:48:15.903] 9: -Dcatdv.mainClass=squarebox.catdv.worker.processor.Server
[66;15:48:15.903] 10: squarebox.catdv.SecureLauncher
[66;15:48:15.903] 11: 1
[66;15:48:15.931] Attaching to helper
[83;15:48:16.172] Status: Waiting for helper process...
[83;15:48:16.172] WGOT Load CatDV library
[83;15:48:16.173] Status: Waiting for helper process...
[83;15:48:16.174] WGOT Attempting to load main class squarebox.catdv.worker.processor.Server
[83;15:48:16.174] Status: Waiting for helper process...
[83;15:48:16.174] WGOT lib=null
[83;15:48:16.174] WGOT args=1
[83;15:48:16.203] Status: Waiting for helper process...
[83;15:48:16.203] WGOT Loading toolkit...
[83;15:48:16.208] Status: Waiting for helper process...
[83;15:48:16.208] WGOT Toolkit squarebox.toolkit.cocoa.MacCocoaToolkit@4a63d8
[83;15:48:16.208] WGOT Set log file to /Users/ingest/Library/Logs/CatDV Worker Helper
[82;15:48:16.339] STDERR Thu Jun 26 15:48:16 ingeststation.body.local java[5159] : kCGErrorFailure: Set a breakpoint @ CGErrorBreakpoint() to catch errors as they are logged.
[83;15:48:16.434] Status: Waiting for helper process...
[83;15:48:16.434] WGOT ready
[70;15:48:16.947] Job 'Approved for YouTube': got 2 clip(s), 2 media(s)
[70;15:48:16.947] adding SClip[ID=1726691.1,name=Grage_Chest_FINAL.mov,tape=,type=Movie,inFrame=240,outFrame=7054,tcFmt=2398,catalogID=1416452,userID=1159802,importSourceID=1726690,sourceMediaID=1726681,posterID=1726685] /Volumes/Worker2/Video Articles/James Grage Chest/Exports/Grage_Chest_FINAL.mov
[70;15:48:16.947] adding SClip[ID=1734887.1,name=ReCUT_Brittney_Shoulders_FINAL_V2.mov,tape=,type=Movie,inFrame=246,outFrame=6650,tcFmt=2398,catalogID=1416452,userID=1159802,importSourceID=1734886,sourceMediaID=1734877,posterID=1734881] /Volumes/Worker2/Video Articles/Brittany Tacy Shoulders/Exports/ReCUT_Brittney_Shoulders_FINAL_V2.mov
[70;15:48:16.947] Skipped 0 of 2 clips (already added to list, offline, wrong type, etc.)
[70;15:48:16.947] Query took 5799ms to find 2 clip(s)
[70;15:48:16.948] Added 0 tasks
[66;15:48:17.934] Status: Sending command for Task 2107 '/T_Klausen_Photo Graphic 1.mov' ...
[83;15:48:20.647] Status: Compressing movie...
[83;15:48:20.771] Status: Preparing to export (10%)
[83;15:48:20.845] Status: Starting... (1%)
[83;15:48:20.847] Status: Converting... (1%)
[83;15:48:20.847] Status: Converting... (2%)
[83;15:48:20.847] Status: Converting... (3%)
[83;15:48:20.848] Status: Converting... (4%)
[83;15:48:20.848] Status: Converting... (5%)
[83;15:48:20.849] Status: Converting... (6%)
[83;15:48:20.849] Status: Converting... (7%)
[83;15:48:20.849] Status: Converting... (8%)
[83;15:48:22.402] Status: Converting... (9%)
[83;15:48:23.754] Status: Converting... (10%)
[83;15:48:25.104] Status: Converting... (11%)
[83;15:48:26.478] Status: Converting... (12%)
[83;15:48:27.883] Status: Converting... (13%)
[83;15:48:28.563] Status: Converting... (14%)
[83;15:48:29.974] Status: Converting... (15%)
[83;15:48:31.298] Status: Converting... (16%)
[83;15:48:32.646] Status: Converting... (17%)
[83;15:48:34.119] Status: Converting... (18%)
[83;15:48:35.476] Status: Converting... (19%)
[83;15:48:36.821] Status: Converting... (20%)
[83;15:48:37.579] Status: Converting... (21%)
[83;15:48:39.394] Status: Converting... (22%)
[83;15:48:40.585] Status: Converting... (23%)
[83;15:48:41.664] Status: Converting... (24%)
[83;15:48:42.743] Status: Converting... (25%)
[83;15:48:43.856] Status: Converting... (26%)
[83;15:48:44.906] Status: Converting... (27%)
[83;15:48:45.471] Status: Converting... (28%)
[83;15:48:46.521] Status: Converting... (29%)
[83;15:48:47.639] Status: Converting... (30%)
[83;15:48:48.678] Status: Converting... (31%)
[83;15:48:49.721] Status: Converting... (32%)
[83;15:48:50.726] Status: Converting... (33%)
[83;15:48:52.115] Status: Converting... (35%)
[83;15:48:52.701] Status: Converting... (36%)
[83;15:48:53.288] Status: Converting... (38%)
[83;15:48:53.881] Status: Converting... (39%)
[83;15:48:54.449] Status: Converting... (40%)
[83;15:48:55.017] Status: Converting... (42%)
[83;15:48:55.620] Status: Converting... (43%)
[83;15:48:56.174] Status: Converting... (45%)
[83;15:48:56.807] Status: Converting... (46%)
[83;15:48:57.439] Status: Converting... (47%)
[83;15:48:58.016] Status: Converting... (49%)
[83;15:48:58.585] Status: Converting... (50%)
[83;15:48:59.148] Status: Converting... (52%)
[83;15:48:59.760] Status: Converting... (53%)
[83;15:49:00.339] Status: Converting... (55%)
[83;15:49:00.905] Status: Converting... (56%)
[83;15:49:01.544] Status: Converting... (57%)
[83;15:49:02.129] Status: Converting... (59%)
[83;15:49:02.682] Status: Converting... (60%)
[83;15:49:03.248] Status: Converting... (62%)
[83;15:49:03.831] Status: Converting... (63%)
[83;15:49:04.388] Status: Converting... (65%)
[83;15:49:04.943] Status: Converting... (66%)
[83;15:49:04.988] Status: Converting... (67%)
[83;15:49:06.376] Status: Converting... (68%)
[83;15:49:07.530] Status: Converting... (69%)
[83;15:49:09.121] Status: Converting... (70%)
[83;15:49:10.903] Status: Converting... (71%)
[83;15:49:12.578] Status: Converting... (72%)
[83;15:49:14.206] Status: Converting... (73%)
[83;15:49:15.355] Status: Converting... (74%)
[83;15:49:16.991] Status: Converting... (75%)
[83;15:49:18.602] Status: Converting... (76%)
[83;15:49:18.915] Status: Converting... (77%)
[83;15:49:18.929] Status: Converting... (78%)
[83;15:49:18.939] Status: Converting... (79%)
[83;15:49:19.454] Status: Compressing... (79%)
[83;15:49:20.215] Status: Flattening... (99%)
[83;15:49:20.215] Status: Finishing (99%)
[83;15:49:20.357] Status:
[83;15:49:20.358] Status:
[83;15:49:22.373] Status: Publish changes to server
[83;15:49:22.373] Status: Opening 'FIT360/Tabitha Klausen/GFX-Tabitha Klausen'...
[83;15:49:22.426] Status:
[83;15:49:22.426] Status: Publish changes to server
[83;15:49:22.504] All change
[83;15:49:22.510] DEBUG: JavaMail version 1.4ea
[83;15:49:22.511] DEBUG: java.io.FileNotFoundException: /System/Library/Java/JavaVirtualMachines/1.6.0.jdk/Contents/Home/lib/javamail.providers (No such file or directory)
[83;15:49:22.511] DEBUG: !anyLoaded
[83;15:49:22.512] DEBUG: not loading resource: /META-INF/javamail.providers
[83;15:49:22.522] DEBUG: successfully loaded resource: /META-INF/javamail.default.providers
[83;15:49:22.522] DEBUG: Tables of loaded providers
[83;15:49:22.523] DEBUG: Providers Listed By Class Name: {com.sun.mail.smtp.SMTPSSLTransport=javax.mail.Provider[TRANSPORT,smtps,com.sun.mail.smtp.SMTPSSLTransport,Sun Microsystems, Inc], com.sun.mail.smtp.SMTPTransport=javax.mail.Provider[TRANSPORT,smtp,com.sun.mail.smtp.SMTPTransport,Sun Microsystems, Inc], com.sun.mail.imap.IMAPSSLStore=javax.mail.Provider[STORE,imaps,com.sun.mail.imap.IMAPSSLStore,Sun Microsystems, Inc], com.sun.mail.pop3.POP3SSLStore=javax.mail.Provider[STORE,pop3s,com.sun.mail.pop3.POP3SSLStore,Sun Microsystems, Inc], com.sun.mail.imap.IMAPStore=javax.mail.Provider[STORE,imap,com.sun.mail.imap.IMAPStore,Sun Microsystems, Inc], com.sun.mail.pop3.POP3Store=javax.mail.Provider[STORE,pop3,com.sun.mail.pop3.POP3Store,Sun Microsystems, Inc]}
[83;15:49:22.523] DEBUG: Providers Listed By Protocol: {imaps=javax.mail.Provider[STORE,imaps,com.sun.mail.imap.IMAPSSLStore,Sun Microsystems, Inc], imap=javax.mail.Provider[STORE,imap,com.sun.mail.imap.IMAPStore,Sun Microsystems, Inc], smtps=javax.mail.Provider[TRANSPORT,smtps,com.sun.mail.smtp.SMTPSSLTransport,Sun Microsystems, Inc], pop3=javax.mail.Provider[STORE,pop3,com.sun.mail.pop3.POP3Store,Sun Microsystems, Inc], pop3s=javax.mail.Provider[STORE,pop3s,com.sun.mail.pop3.POP3SSLStore,Sun Microsystems, Inc], smtp=javax.mail.Provider[TRANSPORT,smtp,com.sun.mail.smtp.SMTPTransport,Sun Microsystems, Inc]}
[83;15:49:22.523] DEBUG: successfully loaded resource: /META-INF/javamail.default.address.map
[83;15:49:22.524] DEBUG: !anyLoaded
[83;15:49:22.524] DEBUG: not loading resource: /META-INF/javamail.address.map
[83;15:49:22.524] DEBUG: java.io.FileNotFoundException: /System/Library/Java/JavaVirtualMachines/1.6.0.jdk/Contents/Home/lib/javamail.address.map (No such file or directory)
[66;15:49:22.968] Status: Finished Task 2107 '/T_Klausen_Photo Graphic 1.mov'
[66;15:49:22.968] -------------------------------
[66;15:49:22.968] Updated Batch[id=3448,status=3,file=null,numTasks=1,numComplete=1,numSuccess=1]
[66;15:49:23.095] Memory used: 5217 of 63936 KB
[66;15:49:23.695] Found 0 complete batch(es)
[66;15:49:23.695] Start next task 0
[66;15:49:23.696] Status: Sending email...
[66;15:49:23.706] Status: Sending email failed
[66;15:49:23.706] javax.mail.internet.AddressException: Missing local name in string ``@bodybuilding.com''
[66;15:49:23.707] at javax.mail.internet.InternetAddress.checkAddress(InternetAddress.java:899)
[66;15:49:23.707] at javax.mail.internet.InternetAddress.parse(InternetAddress.java:819)
[66;15:49:23.707] at javax.mail.internet.InternetAddress.parse(InternetAddress.java:555)
[66;15:49:23.707] at javax.mail.internet.InternetAddress.(InternetAddress.java:91)
[66;15:49:23.707] at squarebox.catdv.worker.$23.$1(Unknown Source)
[66;15:49:23.707] at squarebox.catdv.worker.$23.$0(Unknown Source)
[66;15:49:23.707] at squarebox.catdv.worker.$23$$0.$0(Unknown Source)
[66;15:49:23.707] at squarebox.catdv.worker.$23$$0.$1(Unknown Source)
[66;15:49:23.707] at squarebox.catdv.worker.$23.$4(Unknown Source)
[66;15:49:23.707] at squarebox.catdv.worker.$3.run(Unknown Source)
[67;15:50:14.219] *** Naming.lookup rmi://catdv.body.local/CatDVServer -> CatDVServer_Stub[UnicastRef [liveRef: [endpoint:[10.7.70.53:1099](remote),objID:[38ddffa6:14423678478:-7fff, 2446321902347308753]]]] took too long ***
[67;15:50:14.220]
[67;15:50:14.220] Perform remote: Perform Query
[67;15:50:14.289] Job 'Make Proxy': got 0 clip(s), 0 media(s)
[67;15:50:14.289] Skipped 0 of 0 clips (already added to list, offline, wrong type, etc.)
[69;15:50:14.289]
[69;15:50:14.289] Perform remote: Perform Query
[69;15:50:16.057] Job 'Move to YouTube Catalog': got 1 clip(s), 1 media(s)
[69;15:50:16.057] adding SClip[ID=1652029.6,name=T_Klausen_Photo Graphic 1.mov,tape=,type=Movie,inFrame=0,outFrame=288,tcFmt=2398,catalogID=1520652,userID=152,importSourceID=1652015,sourceMediaID=1651951,posterID=1651973] /Volumes/Worker1/Fit360/Tabitha Fit360/T_Klausen_Exports/T_Klausen_Photo Graphic 1.mov
[69;15:50:16.057] Skipped 0 of 1 clips (already added to list, offline, wrong type, etc.)
[69;15:50:16.057] Query took 1834ms to find 1 clip(s)
[69;15:50:16.058] Added 1 tasks
[68;15:50:16.075]
[68;15:50:16.075] Perform remote: Perform Query
[69;15:50:16.077] All change
Shane Johnson
Re: Worker Node fails sending email
on Jun 30, 2014 at 3:54:17 pm
