CatDV 10.1.1 generates proxy video with black to ProRes 4444!
COW Forums : Square Box CatDV
rudinei soares
on Jun 18, 2014 at 6:06:38 pm
Hello everyone, can someone help me, I'm using 10.1.1 and OS CatDV Professional Mavericks, Original Media ProRes 4444, when proxy is generated with black in the video!
I have installed in your Final Cut 7 0 3, ​​CS6, what is the problem?
thank you!
bryson jones
Re: CatDV 10.1.1 generates proxy video with black to ProRes 4444!
on Jun 19, 2014 at 3:28:47 pm
Could you try to export to the same proxy setting using QuickTime Pro? This will tell you if it's a codec or media or machine issue.
If these exports are black, it's something in those, if not, then I'd report it to Squarebox support.
Let us know!
bryson
bryson "at" northshoreautomation.com
rudinei soares
on Jun 20, 2014 at 12:01:07 pm
The media is 1080 and 4444 proxy 640x360, all proxy are black with video.
Using Compressor to export proxy, the media generates normal.
The CatDV is understanding that it is an alpha channel?
thank you
