Modify subclips in out in catdv
COW Forums : Square Box CatDV
Joel Melancon
on May 5, 2014 at 4:09:00 pm
Is there any way to edit the in and out points of a subclip directly in catdv. I know I can export it to premiere and then revert it to a master clip to change the in/out but I am looking for a way to refine subclips created by the "convert markers to subclips" command, without leaving catdv.
Matthew Stamos
Re: Modify subclips in out in catdv
on May 6, 2014 at 6:06:27 pm
Great question and yes under the logging menu you can toggle sub clip limits. There is also a key command shift U.
Here is a link the the shortcuts http://www.squarebox.com/shortcut-keys/
Joel Melancon
on May 8, 2014 at 1:42:31 pm
Great news. Thanks!
