CatDV 8.1.5
COW Forums : Square Box CatDV
Rolf Howarth
CatDV 8.1.5
on Jul 28, 2010 at 9:58:23 pm
CatDV 8.1.5 is now available at
From the release notes:
Fix an issue when dragging and dropping clips from one catalog to another in the server tree. Fix an issue with missing metaclip members after publishing changes. Apply Tmecode Offset command now lets you apply contiguous timecode. Right click on the event markers table to copy and paste markers. When you create a new subclip it will inherit any markers from the parent, and also use the subclip naming scheme defined in Preferences. Export As Still now rounds the size up rather than down so no resolution is lost. Additional preference options relating to copying of files and chapter markers. Preserve blank lines in the verbatim logger. Minor changes to media dialog, including full screen playback. Fix an issue where the audio track of clips sent to FCP via XML might appear offline. Import FORK XML files. Fixes relating to importing XML batch files. Other minor fixes.
© 2018 All Rights Reserved
