Worker Node fatal initilisation
COW Forums : Square Box CatDV
Nick Clausen
on Feb 27, 2014 at 3:54:49 pm
Hi, getting this strange error when starting the worker node...any suggestions? Thanks!
bryson jones
Re: Worker Node fatal initilisation
on Feb 27, 2014 at 5:44:11 pm
It's telling you where it hurts.
There's an illegal character in the XML config files. As a test, backup your worker.xml and workset etc. (Contact support for the exact files) and then try restarting Worker clean.
http://www.squarebox.com/catdv-backups/ That's a link to where the files we're speaking of are.
If that works, you can then check the XML configs for the bad character using a text editor. Or, if it's a small config, just rebuild it or restore from a backup of your Worker XML files. (You are keeping a backup right?)
That's all I got, but contact support because this may be a known issue that I've just not seen but that Java error is pointing to your config or workset files.
bryson
bryson "at" northshoreautomation.com
Nick Clausen
on Feb 27, 2014 at 5:50:38 pm
Thanks to squarebox support's super fast response here's what they said:
i think your workset file may have become corrupt this is the list of all your worker tasks
to fix stop the worker rename the file from workset.xml to something else - eg workset_old_feb27.xml and either restart worker which will automatically create a new workset file or replace it with the workset.bak file
you' 'll find the workset file here
The worker.xml and workset.xml files are located at:
PC
C:\Users\?USER NAME?\AppData\Local\Square Box\worker.xml
C:\Users\?USER NAME?\AppData\Local\Square Box\worksetr.xml
MAC
MAC /Users/?USER NAME?/Library/Application Support/worker.xml
MAC /Users/?USER NAME?/Library/Application Support/workset.xml
cheers dougal
bryson jones
on Feb 28, 2014 at 1:25:08 am
Excellent and thanks for sharing that solution here!
bryson
