What is this icon in CatDV?
COW Forums : Square Box CatDV
Mark Underkofler
on Jan 27, 2014 at 10:40:09 pm
I get a weird icon when I use CatDV and attempt to drag a scene into Premiere Pro CC.
Also, CatDV has a Export to Adobe Premiere CC, but nothing is sent to PP. I suspect it has something to do with a screwed up Exporter utility in Premiere.
Any one have an answer?
Thanks in advance,
Mark Underkofler
Robb Harriss
Re: What is this icon in CatDV?
on Jan 27, 2014 at 11:20:24 pm
"Stop, a rocket is striking"
Non-linear: all the time and nothing but.
Dougal Matthews
on Jan 28, 2014 at 12:55:34 pm
hi Mark
we don't support drag and drop with Adobe Premiere as we need to use some Adobe tools to send the information form catdv to premiere
there are a few steps to get this working
firstly in the catdv preferences under the export section you need to tell catdv which flavor of premiere your working with ( cs6 /cc ) as in the following screenshot
to actually send files to premiere click on a file or shift select a group of files and then right click and select export as and then send to premiere cc ( this will show the option you chose in the set above so if you've selected CS6 it will say "send to premiere CS6" )as in the following screenshot
the first time you try this you will be prompted to find the location of the "Adobe extendscript toolkit.app ( or .exe on windows) as in the following screenshot
this can be found
 In Windows: {Program Files}\Adobe\Adobe Utilities - CC\ExtendScript Toolkit
Cc.exe
 In Mac OS: In /Applications/Utilities/Adobe Utilities - CC/ExtendScript Toolkit
CC.app,
once you've done this Catdv will send the selected items to premiere
next time you use export as >> send to premiere it will just work
i hope this helps you get send to premiere working
thank you Dougal
Improvise Adapt and Overcome
bryson jones
on Jan 28, 2014 at 6:13:04 pm
Dougal, thanks for the step by step man.
bryson
bryson "at" northshoreautomation.com
Mark Underkofler
on Jan 28, 2014 at 6:54:59 pm
Works like a charm. It was the Adobe ExtendScript Toolkit that was causing the problem.
Back to normal now. Thank you very much for your guidance.
Mark
Dougal Matthews
on Jan 29, 2014 at 11:45:46 am
no problem
I've added this as a tutorial on our website its worth keeping an eye on the tutorials pages here
http://www.squarebox.com/catdv-tutorials/
were constantly adding new guides tips and tricks
thank you dougal
