Slow framerate playback in Pro trial using Quicktime
COW Forums : Square Box CatDV
Shane French
on Jan 9, 2014 at 10:50:31 pm
Am evaluating CatDV won Win 7. I';m having an issue with playback of h.264 files. The framerate is slow (guestimate 12-15 fps) within CatDV. Have tried regular and protected mode player within CatDV, same slow result.
Playing same files in standalone Quicktime Player works fine, video is smooth.
Now, I have realized that if QT's audio playback is set to anything other than 16-bit 44.1, the player exhibits the same issues. Who knows why (of course, the same files play fine in all other apps). Does CatDV force playback at a different audio setting? Could explain the issue I suppose.
Additionally, playback is smooth within CatDV using Directshow, etc...but it causes VERY frequent crashes (can provide error log if anyone wants to look at it).
This is a fresh install of Win 7 64-bit. nVidia GTX680.
Hoping I can get one of the two options working satisfactorily!
Shane
bryson jones
Re: Slow framerate playback in Pro trial using Quicktime
on Jan 11, 2014 at 1:41:15 am
Shane, are the files on a local drive or on a network?
There are many issues with QT files playing over a network on Win.
(You might search here for UNC path issues.)
Hope that helps.
bryson
bryson "at" northshoreautomation.com
Shane French
on Jan 11, 2014 at 2:33:55 am
Hey Bryson,
Nope, they're on a locally attached SAS RAID - blazing fast.
Shane
Charlie Langrall
on Jun 2, 2014 at 10:24:43 am
Was this issue resolved? I'm also seeing slow/hitchy playback of h.264 proxies in CatDV Pro 10.1.1 on Windows 7 (not a trial version). The same proxies play smoothly in QuickTime Player, Windows Media Player and they work as expected in the web client.
-Charlie Langrall
