Locating lo res library references.
COW Forums : Square Box CatDV
Bruce Rawlings
on Dec 26, 2013 at 9:28:52 am
I have been using Catdv for a while and want to make a back up of the library. I cannot locate the folder with the material in it. Where is it located in relation to the program and what would it be called?
Dave Clack
Re: Locating lo res library references.
on Jan 2, 2014 at 10:35:52 am
Hi Bruce, each asset in the CatDV database has a "media path" and "proxy file" that shows the location of the media and a lo res version.
If you right click on an asset then you should have the options to "reveal in finder" or "reveal proxy in finder" too
Hope that helps
Dave
