Batch exporting file summaries out of CatDV
COW Forums : Square Box CatDV
Collin Seaman
on Oct 31, 2013 at 9:07:17 pm
Is it possible to batch export clip summaries with the desired metadata out of CatDv into one large or multiple text docs or pdfs? I'm looking to create a simple text document(s) that have all the basic information and specific user defined fields that I can hand off. XML's aren't bringing the desired text into excel or word as cleanly as I'd like. Maybe I'm not doing it right. Summary pages are perfect but it seems you can only access/export them one at a time per clip (file).
Any thoughts? Thanks very much.
Dougal Matthews
Re: Batch exporting file summaries out of CatDV
on Nov 5, 2013 at 1:02:17 pm
hi Colin
there are at least a couple of ways of going about this
you can export data in CatDV in a number of ways see http://www.squarebox.com/client-manual-additional-importers-and-exporters/ for the options but using catdv's own xml will give you all the metadata for a selection of clips
alternatively by creating custom views and then printing them you can achive a more bespoke output in a verity of formats see the links below for pointers on how to customize displays and print
customizing the display
http://www.squarebox.com/tutorial-customising-catalogs-display/
printing from CatDV http://www.squarebox.com/client-manual-printing/
I hope this helps you reach your aims in terms of export
Cheers Dougal
Improvise Adapt and Overcome
but remember: out of good , quick and cheap
you can only pick TWO ...
Collin Seaman
on Nov 6, 2013 at 5:21:42 pm
Dougal,
Thanks very much, this helps out tremendously!
Cheers.
