CatDV iOS apps Now Available from the App store
COW Forums : Square Box CatDV
bryson jones
Re: CatDV iOS apps Now Available from the App store
on Sep 19, 2013 at 4:17:48 pm
Excellent work guys.
One note to users, you might need to add the port number to your server setup to get this rolling.
ex: xx.ipa.ddr.ess:port# or something like 8.8.8.8:8085
bryson
bryson "at" northshoreautomation.com
Matthew Stamos
on Sep 19, 2013 at 5:01:37 pm
Good tip Bryson, also look out soon for new builds as they make refinements for iOS7.
The team has worked hard on these apps and it shows!
Jack Lenk
on Oct 1, 2013 at 9:14:48 pm
Trying to get this to connect... so:
Description - anything
Host Name - 192.168.168.5:8080
User - jack
Password - xxxx
Correct? It's not doing anything when I click to connect... (iOS7)
Jan Fosserud
on Oct 10, 2013 at 11:44:20 am
Same thing here.
If I try 10.10.10.10:8080 I get the error message: "/api/2/session/" and if I try 10.10.10.10:8080/catdv2/ the app connects but just quits right afterwards.
Matthew Stamos
on Oct 10, 2013 at 9:45:50 pm
On the CatDV server are you able to see the web client at this url?
http://localhost:8080
or "hostname":8080
In the iOS app I have not had to use the port just he IP address on several machines so give that a try if you have not already.
Jan Fosserud
on Oct 11, 2013 at 5:42:52 am
I get the same "/api/2/session/" error when I try just the IP adress on the app.
On my CatDV server I have to type http://localhost:8080/catdv2 to get the to web version of CatDV. http://localhost:8080 just brings me to apache tomcat.
I'm currently running CatDV Server 6.7. Perhaps its only supported in 6.8?
http://www.squarebox.com/advanced-tomcat/?zsid=2619141d7f97ee8
Jack Lenk
on Oct 25, 2013 at 3:15:56 pm
localhost:8080 brings me to the default Tomcat home page on the catdv machine.
John Mininger
on Nov 9, 2013 at 2:44:34 pm
So far I am able to view clips, but I cannot get any of them to play. I just receive an error popup "there was an error whilst playing this clip" message. I would assume that has to do with proxy file format?
John Mininger
Video Producer, Jackson Marketing Group
