replaceClip failed Error
COW Forums : Square Box CatDV
Jessica Muth
on Jun 18, 2013 at 4:05:30 pm
We have a client that is receiving the following error in CatDV:
replaceClip failed (Data truncation: Data too long for column 'history' at row 1)
This error is occurring when trying to modify 18 of 2000 clips that were archived. Any idea what this error might be related to?
Jessica Muth
jmuth01@gmail.com
bryson jones
Re: replaceClip failed Error
on Jun 18, 2013 at 5:35:30 pm
It's a SQL error I believe. Can you offer some info on your system? Are you running MySQL?
If so, you might need to contact your sysadmin or support and have them clean up your db. That's the first step I'd take.
bryson
bryson "at" northshoreautomation.com
Sebastien Bertrand
on Jun 19, 2013 at 12:50:04 pm
This is a known bug. It has been corrected in the latest versions. If you are running the latest version, then it is a new bug. You should contact squarebox support.
Sebastien Bertrand
Systems Technologist
http://www.tfo.org
bryson jones
on Jun 20, 2013 at 4:08:53 pm
Thanks for this Sebastien. Do you know the versions affected, or at least when the fix hit?
I've not seen this but CatDV is one app that I do trust the upgrades on and try to keep as current as possible.
bryson
Sebastien Bertrand
on Jun 20, 2013 at 4:13:41 pm
It was around version 10.0 that I had that problem if I remember well. But it might have been in one of the latest 9.x versions. I'm not sure anymore.
Sebastien Bertrand
http://www.tfo.org
