20000 timelapse files
COW Forums : Square Box CatDV
Lee Warner
on May 22, 2013 at 6:39:13 pm
What's the best way to get Worker to pull in 5000+ files into a project catalog? Currently Worker seems to be ignoring the watchfolder that has all these DSLR files.
Scott Goddard
Re: 20000 timelapse files
on May 22, 2013 at 10:02:40 pm
Depends on how much you are paying him..
Set the worker to dev mode and test it with one image on it's own in the watch folder. It could be an issue with the number of files causing the worker to fail. I have not tested anything near that number at once. If you know your setup is working with 1 file then try with a smaller batch of a 1000 etc.
Scott Goddard
Neo Verite Limited
http://www.neoverite.com
Lee Warner
on May 23, 2013 at 5:02:37 pm
I've decided to break the image sequences into separate catalogs based on content and keep them organized under project folders. That way the max files in any given catalog is under 5000.
