File Maker and Cat DV
COW Forums : Square Box CatDV
jack Bibbo
on Jan 22, 2013 at 6:13:53 pm
Can I import Filemaker Pro info into CAT DV.
We have logged all footage via Filemaker, we are considering implementing CATDV however I could not imagine having to reenter all that meta data for a 450 hour film.
thanks in advance
jack
bryson jones
Re: File Maker and Cat DV
on Jan 22, 2013 at 8:29:25 pm
Yes, you can export in several formats out of Filemaker and import that into CatDV. (Sometimes a trip through Excel is nice to clean things up.)
Tab Separated Text and XML both work.
If you need to do this often, probably an XML with an XSLT to match CatDV's import format is best.
bryson
bryson "at" northshoreautomation.com
Matthew Stamos
on Jan 24, 2013 at 2:53:09 pm
Here is a link to an FAQ along those lines!
http://www.squarebox.co.uk/faq145.html
jack Bibbo
on Jan 24, 2013 at 6:36:13 pm
excellent thanks guys.
