"Check Archive Status..." error
COW Forums : Square Box CatDV
Jeff Schaap
on Jan 15, 2013 at 1:31:23 am
Trying to use CatDV to request archive status of clips in CaDV...
Whenever I select a file or group of files in CatDV and select Tools > Check Archive Status, in a window I get:
Failed to check Cache-A archive status ([Ljava.lang.Object; cannot be cast to java.util.Map)
And of course I have no idea what that means.
This is CatDV9 Professional (Mac) with Cache-A (latest and greatest software on it I assume because Cache-A spent several days just recently working on it).
Anyone have ideas on what the issue may be?
Argh,
Jeff Schaap
Matthew Stamos
Re: "Check Archive Status..." error
on Jan 15, 2013 at 4:13:03 pm
Hey Jeff can you send screen shots and logs and this description to support@squarebox.com
Jeff Schaap
on Jan 16, 2013 at 7:08:08 pm
Will do!
Rolf Howarth
on Feb 13, 2013 at 1:25:02 pm
This is fixed in the forthcoming CatDV 10.0.2 update. Cache-A have made some improvements to the Check Archive Status API and you need the new CatDV update to make use of them.
