CatDV Archive Option
COW Forums : Square Box CatDV
Scott Goddard
on Nov 20, 2012 at 1:01:12 pm
We are trying to clarify exactly what versions are needed to run the archiving option on CatDV. This is to work with a CacheA Pro Cache.
Would I be correct in thinking it is simply just the 'professional version' and the added extra of the 'archiving option'? We had been given some information by a reseller that the archiving option can only be installed on a server version of CatDV and with worker node.
Rolf, Bryson, can you clarify?
bryson jones
Re: CatDV Archive Option
on Nov 20, 2012 at 5:09:48 pm
No server needed, you can run "archiving" on a standalone copy of CatDV Pro just fine.
The reason server is suggested is that it's harder to manage large data sets without server but you can certainly do it.
bryson
bryson "at" northshoreautomation.com
Scott Goddard
on Nov 20, 2012 at 5:15:35 pm
Cheers Bryson
Scott
Neo Verite Limited
http://www.neoverite.com
