CatDV Pro 7.0.3 preview failed error (-108)
COW Forums : Square Box CatDV
Sally Truong
on Oct 17, 2012 at 2:30:07 pm
Hello Experts,
I left CatDV on overnight so I could build previews to save time. However this time the batch was not finish by the time I got to work the next day and I had to cancel before it was done. In the past that this had happen I would go to Manage Preview Files and delete the previews from there. However this time the folder is empty I can't delete the root folder either. I have tried going to the path directory without using CatDV and deleted the folder from there.
I still cannot build a preview file. The message insert filename failed (-108)is my only clue to what is wrong. What can I do to solve this and any tips to how I can delete previews in a batch?
Thank you,
Sally Truong
Rolf Howarth
Re: CatDV Pro 7.0.3 preview failed error (-108)
on Nov 26, 2012 at 8:46:02 pm
-108 is a memory full error. You can delete multiple previews by going in via the Finder and deleting folders if necessary. You mght also want to consider upgrading as CatDV 7 is a few years old now and there have been a lot of fixes and improvements since then!
