Installing CatDV on two computers
COW Forums : Square Box CatDV
Khashyar Darvich
on Oct 8, 2012 at 4:31:02 pm
Hi Everyone,
I am considering purchasing CatDV, and was wondering whether the CatDV license allows for installing the software on two computers owned by the licensee?
I searched on the software website and Google, and didn't find any information about multiple installations.
Thank you.
Producer-Director
Wakan Films
Hollywood, CA
http://www.wakan.com
Khashyar Darvich
Re: Installing CatDV on two computers
on Oct 9, 2012 at 8:58:46 am
Hi Everyone,
I think that I found the answer in a March 2011 thread in this forum:
http://forums.creativecow.net/thread/278/926
"You normally need a license for each machine that's running CatDV, whether actively logging or just searching the database. However, if one person has two machines they're the main user of (for example, one laptop and one desktop, or one at work and one at home) and they only use CatDV on one or the other at a time then you're allowed to share a license between the two machines.
The upgrade from CatDV Pro standalone to the Workgroup Server is very seamless. It's the same desktop application, the only difference is whether you save catalogs to a local file or publish them to the server so they're available to everyone.
(The only slight inconvenience with buying one then upgrading a short time later is you might end up with separate license codes to manage, eg. a single user and a 4-user license. If you think you're quite likely to go for a server but aren't 100% sure you want to commit to that until you've tried it, just drop us a line requesting a fully functional temporary evaluation code while you try it out.)"
Producer-Director
Wakan Films
Hollywood, CA
