Finding the right code for using user field as a variable in Worker
COW Forums : Square Box CatDV
Henrik Helms
on Sep 27, 2012 at 6:10:37 pm
Hi!
I must say - I am NOT an expert in programming. But I have made a task in worker which will start if the status is put to "Make web proxy" then it will create a webproxy and I want it to be put in a new catalog which name is set in user field 19. Which code do I write to the catalog name field in worker?
Kind regards Henrik
Matthew Stamos
Re: Finding the right code for using user field as a variable in Worker
on Sep 27, 2012 at 6:38:01 pm
Look in Worker Read me PDF
${id} Value of arbitrary clip fields, eg. ${U12} is User12, ${NT} is the Notes field
Henrik Helms
on Sep 27, 2012 at 6:49:35 pm
Greetings
Henrik Helms
dBA MEDIA
