Basic PullParser error
COW Forums : Square Box CatDV
John Sorensen
on Sep 26, 2012 at 4:33:14 pm
Has anybody seen this error before? I scanned an external G-Tech drive with some .avi files and some of the files came back in the catalog with this import note:
BasicPullParser: readBytes(): Reached end of stream while trying to read 4 bytes
I suspect these files might have some issues, but only some of them are coming back with this log note. The only thing I could figure out from a quick google search is that it is java related, but I can't tell if this indicates an issue with the file or just a java hiccup with CatDV.
This is CatDV Pro 8.1.11 server running on a Mac Pro 12 core with OS 10.6.8
John Sorensen, VP of Production
Grace Creek Media
bryson jones
Re: Basic PullParser error
on Sep 26, 2012 at 11:40:26 pm
Do the files play? If not, there's your answer.
If so, then we get to look into CatDV but I seldom see a "good" playable file that won't import.
However, I don't use avi much so it may be specific to that wrapper.
bryson
bryson "at" northshoreautomation.com
Rolf Howarth
on Sep 27, 2012 at 9:56:28 pm
Do you have a small example file that shows the error that you could send to support@squarebox.com? It might be the file is corrupted but if you have quite a few files that show the same error then it could be an problem in our AVI metadata extraction code.
