CatDV 10 and Premiere Pro Panel
COW Forums : Square Box CatDV
Justin Stoll
on Sep 19, 2012 at 7:21:59 pm
Is it true that with CatDV 10 you will have 'panel' integration with Premiere Pro so you can have the CatDV Interface directly within Premiere?
bryson jones
Re: CatDV 10 and Premiere Pro Panel
on Sep 19, 2012 at 9:01:54 pm
Rumors are flying.
Stamos! Spill! ;)
bryson
bryson "at" northshoreautomation.com
Matthew Stamos
on Sep 19, 2012 at 9:58:12 pm
Yes the rumor is true I have yet to play with this though and keep in mind this needs a CatDV server but don't worry we will be offering a 1 user server for the Lone Rangers out there!
Alan Conn
on Nov 8, 2012 at 5:44:06 pm
Is the Premiere Pro Panel only available for the latest version of Server 6.7b9? Due to a Java issue and needing to keep my Web Client online I am still running 6.8b7.
Any workarounds?
We are making the move to Premiere CS6. We can't give up our group workflow for FCX, and this integration with CatDV is a helpful motivator for FCS7 holdouts.
I know focusing on why the Java problem is probably where I should be looking but figured I'd ask.
Rolf Howarth
on Nov 26, 2012 at 9:03:08 pm
We are aware of one issue with the web client giving "java.lang.NoSuchMethodError: java.lang.String.getBytes(Ljava/nio/charset/Charset;)[B" if you use 6.7b9, which is due to using Java 1.5 with the new version of GWT we now include. Can you upgrade to Java 1.6 to resolve this?
