CATDV on an Edit Share System
COW Forums : Square Box CatDV
Jordan Bosch
on Aug 27, 2012 at 5:32:57 pm
Hi Guys,
Just about to install our CATDV System with an LTO CACHE-A and a bunch of other goodies. One question that is popping up is how CatDV will work with our current Editshare system set up. Has anyone set up CAT-DV with Editshare? Any quirks we should watch out for? Or will nothing change.
Thanks for any input!
Jordan Bosch
Zoomwebvideo.com
bryson jones
Re: CATDV on an Edit Share System
on Aug 29, 2012 at 1:28:40 pm
CatDV works with any mountable filesystem. It really doesn't care.
The performance and permissions of the storage apply. If it's fast, you can play hires media, if it's slow, you cannot.
If you have write permissions, CatDV can move and add things, if you only have read, then CatDV has read.
CatDV is "compatible" with everything from a USB stick to a million dollars worth of DDN drives. Let us know how it goes.
bryson
bryson "at" northshoreautomation.com
