Creating a sequence from FCP, XML-5 in CatDV
COW Forums : Square Box CatDV
Joe TheVisualist
on Aug 10, 2012 at 4:49:29 pm
Here's one for you lot, Im having trouble importing any XML into a catalog. The plan is to import the XML and create a sequence, basically im testing the XML/Sequence being "Round Tripped" from FCP7 to CatDV and vice verse. thoughts? did i leave out any pertinent info?
thanks in advance!!
Rolf Howarth
Re: Creating a sequence from FCP, XML-5 in CatDV
on Aug 20, 2012 at 10:42:56 pm
What does "having trouble" mean exactly? Try exporting the XML from Final Cut as an .xml file and then importing it into CatDV using the Import As > Final Cut 7 XML command. Are any error messages shown?
PS. Has something gone wrong with the COW forum? I can't see this item in the View Posts By Newest Post view.
Joe TheVisualist
on Aug 21, 2012 at 5:13:50 pm
this is the error MSG i get when i follow your exact instructions.
Rolf Howarth
on Aug 21, 2012 at 6:03:13 pm
What version of CatDV are you running?
That message shouldn't occur on a Mac and looks like you might have a corrupted preferences file. Could you send us the CatDV Error Log (accessible from the Help menu) to support@squarebox.com?
