Worker Node proxy creation of spanned MXF Clips (Metaclips)
COW Forums : Square Box CatDV
Nick Shookla
on May 1, 2012 at 4:00:32 pm
Hello!
I've noticed that when I send clips to Worker node for proxy automation, if there are any spanned MXFs (Metaclips from CatDV) in the list then it will only create a proxy for the first clip in that metaclip.
If I create the proxies straight in CatDV via "Build Proxies", everything is fine -- it creates one proxy that resembles the entire metaclip.
Does it sound like a setting could be wrong in Worker node somewhere? I'm just having it create H264 MOV proxy files, same thing that I create in the CatDV side (which works for spanned clips).
Thought I would check here before entering a support ticket.. thanks in advanced!
-Nick
bryson jones
Re: Worker Node proxy creation of spanned MXF Clips (Metaclips)
on May 3, 2012 at 7:11:58 pm
This should be sorted in Worker 5 (which should be out any time now.) I'm betting it's just a bug in 4.
Any of the Squarebox crew on this?
bryson
bryson "at" hidefcowboy.com
hidefcowboy.com
