Worker Node and Custom Fields in Server Query tab...
COW Forums : Square Box CatDV
Dan Nethery
on Apr 30, 2012 at 10:12:26 pm
How do I make my custom fields to show up in the server query term tab when I creating an action that reacts to a Server Query trigger..
Thanks for any help!
dan.
bryson jones
Re: Worker Node and Custom Fields in Server Query tab...
on Apr 30, 2012 at 10:49:08 pm
First, you need to check how many user fields you have enabled in the Worker's general preferences. That's a commonly overlooked setting. The default is 3.
If you are looking for the names, if you save a field definition set in CatDV Pro, you can enter that set's name in the server preferences in the Worker Node and it will take the names from the Server and display them for your programming pleasure.
bryson
bryson "at" hidefcowboy.com
hidefcowboy.com
