Multi-Check Box
COW Forums : Square Box CatDV
Geof Gilland
Multi-Check Box
on Apr 27, 2012 at 8:26:21 pm
I have read the previous posts about creating multi-check boxes. However, I think I need more detailed instructions than are listed here. Is there a video tutorial about the subject or can someone walk me through it. I have read the following thread:
I have managed to create a pick-list, but this checkbox seems to confound me.
Thank you,
Scott Goddard
Re: Multi-Check Box
on Apr 30, 2012 at 12:02:48 am
Hi Geof,
Yes its a little confusing, but the reference guide does explain it.
Basically you create a multi checkbox not in the pick list section but in the 'user column' section under preferences.
Type your list of checkboxes that you want like this, for example lets say you wanted to checkbox what the weather was like on a shoot, your user column name will look like this:
Weather:Sunny:Cloudy:Raining:Thunder:Snowing etc..
So the first word is the name of the field and then the colons separate the names of the checkboxes. Then you just need to choose Multi Checkbox from the type column and you are good to go...
Néo Vérité Limited
© 2018 All Rights Reserved
