Worker node -sequence
COW Forums : Square Box CatDV
Tomo Sabljic
on Mar 8, 2012 at 8:01:50 am
We are using worker node version 4.0.5 and enterprise server 6.6b.12 running on OSX.
There are few things that we would like to automate if that is possible at all?
1) Export CAT DV xml for sequence through worker node-server query trigger.
This is possible for video clip but I can not make this is working for sequence.
2) copy/paste metadata trough worker node from existing sequence detail in CAT DV (seq name for example is "test0203") to file being imported (file name is "").
Sequence and file have the same name.
I know this is not question that is part of support, and it is customizing of customer system, but if you can help me at least with answer is this possible or not, I would be very grateful for that.
Thanks a lot in advance
Best regards,
© 2018 All Rights Reserved
