Previously Saved Log
COW Forums : Square Box CatDV
steve leary
on Jan 4, 2012 at 9:48:22 pm
I inadvertently deleted a field of information from a pick list I made on an entire catalog. Is there a way to go back in time to look at a previously saved log and re-save it as new - like you can do with a project in Final Cut Pro?
Rolf Howarth
Re: Previously Saved Log
on Jan 5, 2012 at 2:00:22 pm
If you're working standalone and save catalogs to a .cdv catalog file then CatDV will normally save the previould catalog as a .old file. If you're using the CatDV Server however then it doesn't keep old versions I'm afraid as this would quickly use up a lot of space. (Deleted clips are moved to the recycle bin however, and deleted after two weeks.)
bryson jones
on Jan 5, 2012 at 6:20:56 pm
Not that it helps you if you don't have one, but here's a post about setting up a backup job.
If you guys out there aren't getting at least a nightly, please set it up now.
http://forums.creativecow.net/readpost/278/875
bryson
bryson "at" hidefcowboy.com
hidefcowboy.com
Matthew Stamos
on Jan 10, 2012 at 4:28:25 pm
This database backup post should be a sticky!
