How to mark unused footage
COW Forums : Square Box CatDV
Carsten Orlt
on Dec 4, 2011 at 10:43:28 pm
I'm trying to work out how I could make a list/create a new catalogue from a set of clips with only the footage I HAVEN'T used in a sequence.
Idea is that after I finish a film I would like to mark all 'not-used' footage to make it available for stock footage library use.
Tricky bit is that within a clip several sections could be used and also unused. I know that I can mark all clips used in a sequence and therefor can get the reverse selection being the unused whole clips. BUT often there are good bits in a clip that is partly used. So marking the whole clip would make me loose these bits.
Any idea how this could be done with CatDV?
Any help is much appreciated
© 2018 All Rights Reserved
