search tape name in 'browse catalogs' window
COW Forums : Square Box CatDV
Swami Kevala
on Mar 4, 2010 at 2:22:54 am
Hello,
We are running the standalone version of CatDV. We are backing up SONY XDCAM EX3 HD footage. We backup our data on LTO4 tapes, and create a separate catalog for the data on each LTO4 tape.
Our files/pathnames are like this:
Pongal Tourist Festival 2010 at Semmedu 16-Jan-10 - Cam I
- BPAV
So - the tape name contains all the event metadata, so I need to be able to search for words in the clip tape name over all our catalogs. (For example I should be able to search for the word "festival", and get clips back from all the catalogs - using the "Browse Catalogs" window).
However, it seems that the Browse Catalogs window does not search the clip tape name.
I understand that this functionality may be available using the workgroup version - but we are not in a position to get that right now. Is there any possibility that this feature could be added to the standalone version?
Kind Regards
Swami Kevala
Rolf Howarth
Re: search tape name in 'browse catalogs' window
on Mar 4, 2010 at 9:38:47 am
You're right, it doesn't seem to search Tape and probably should, so we'll try to add that in the next update. (Currently it searches clip Name, Bin, Notes and all the user-defined fields).
bryson jones
on Mar 8, 2010 at 5:00:21 pm
For now, maybe create a new "tape" field, that's a user field and then Bulk Edit (under the "Tools" menu) the tape name into that new field. That way you could search it.
bryson
bryson "at" hidefcowboy.com
hidefcowboy.com
