xdcam proxy size
COW Forums : Square Box CatDV
Swami Kevala
xdcam proxy size
on Mar 3, 2010 at 12:03:39 pm
Hello,
We are using CatDV to manage a collection of HD video taken with a Sony XDCAM EX3 camera. We have a Matrox compressHD card which we want to use to create H.264 proxies.
I am running into problems maintaining the correct aspect ratio (16:9).
On the Preferences/Previews & Thumbnails window I need to specify a size. But it only allows me to specify the width and then automatically sets the height by itself. It will not let me set a size with 16:9 aspect ratio.
I then select the "Custom" option, where I then have a number of options to specify the size.
It seems that these two things are conflicting with each other. I cannot seem to produce HD proxy files with the size I want (512x288). Does anyone know how I can do this?
Kind Regards
Swami Kevala
bryson jones
Re: xdcam proxy size
on Mar 3, 2010 at 3:52:57 pm
If you click the "Customise" button and go into the video settings you can set a size in the QT dialog box, that's anything you like.
It should override the first pulldown window in the "P&T" preference pane.
Try that and see if it works it out.
bryson
bryson "at" hidefcowboy.com
hidefcowboy.com
Swami Kevala
on Mar 4, 2010 at 2:09:10 am
Thanks - that worked.
I needed to uncheck the "Preserve aspect ratio using" box.
