One particular computer will not connect
COW Forums : Square Box CatDV
jason levy
on Oct 22, 2011 at 4:43:43 pm
Me again. I have workgroup server and several logging station set up and running fine. On one particular computer I am able to connect to the server (and can see the server stats, people connected etc. ) but when I try to get the catalog info a message comes up along the lines of " getting data from server" (I'm not in front of it) and it never gets the catalog info, just hangs there forever, unless I hit "abort". )
As I say all the other stations are working fine.
Thoughts?
jason
bryson jones
Re: One particular computer will not connect
on Oct 23, 2011 at 5:48:12 pm
Check that there's no firewall software blocking port 1099. (that's the default port for CatDV Server.)
Also, check and see if that machine has Atto software loaded on it.
If it does, you may need to set the port from 1099 to 1199 on your server setup.
If you do this, then the address you connect to will contain the port number instead of just the ip address or hostname.
192.168.x.x:1199
instead of-
192.168.x.x or whatever it is.
See if that helps at all.
bryson
bryson "at" hidefcowboy.com
hidefcowboy.com
jason levy
on Oct 24, 2011 at 3:16:21 pm
Doesn't seem to be any firewall active. Can't figure it out. Certain computers cannot access the catalogs though they seem to be logged on to the server. Some operations do not work.
Other computers access the server perfectly.
stymied.
j.
Rolf Howarth
on Oct 23, 2011 at 9:30:12 pm
That sounds a bit odd. I would suggest you quit CatDV on that machine and relaunch it. If the problem recurs, please send the CatDV Error Log from that machine to support@squarebox.co.uk.
jason levy
on Oct 24, 2011 at 3:16:39 pm
Have quit several times. Sent you a log.
here it is again:
[16;16:36:52.082] at squarebox.catdv.server.CatDVServer$$0.run(Unknown Source)
[16;16:36:52.082] ===== Shutdown complete at Sat Oct 22 16:36:52 PDT 2011 =====
[1;16:37:27.701]
===== Starting at Oct 22, 2011 16:37:27 =====
[1;16:37:27.702] CatDV Server 6.6b6
[1;16:37:27.702] Loading properties file : catdv.properties
[1;16:37:27.703] Creating RMI Registry on port 1099
[1;16:37:27.881] awt.nativeDoubleBuffering = true
[1;16:37:27.881] awt.toolkit = apple.awt.CToolkit
[1;16:37:27.881] catdv.allowAnonymous = true
[1;16:37:27.881] catdv.database = jdbc:mysql://localhost/catdv?user=catdv&password=catdv
[1;16:37:27.881] catdv.extraDetails = false
[1;16:37:27.881] catdv.housekeeping = true
[1;16:37:27.882] catdv.rmiport = 1099
[1;16:37:27.882] catdv.useRecycleBin = true
[1;16:37:27.882] catdv.useRoles = true
[1;16:37:27.882] catdv.webDownloads = false
[1;16:37:27.882] file.encoding = MacRoman
[1;16:37:27.882] file.encoding.pkg = sun.io
[1;16:37:27.882] file.separator = /
[1;16:37:27.882] ftp.nonProxyHosts = local|*.local|169.254/16|*.169.254/16
[1;16:37:27.883] gopherProxySet = false
[1;16:37:27.883] http.nonProxyHosts = local|*.local|169.254/16|*.169.254/16
[1;16:37:27.883] java.awt.graphicsenv = apple.awt.CGraphicsEnvironment
[1;16:37:27.883] java.awt.printerjob = apple.awt.CPrinterJob
[1;16:37:27.883] java.class.path = lib/server.jar:lib/jaxp.jar:lib/parser.jar:lib/jakarta-regexp-1.2.jar:lib/mm.mysql-2.0.14-bin.jar:lib/mysql-connector-java-3.1.12-bin.jar
[1;16:37:27.883] java.class.version = 50.0
[1;16:37:27.883] java.endorsed.dirs = /System/Library/Frameworks/JavaVM.framework/Versions/1.6.0/Home/lib/endorsed
[1;16:37:27.883] java.ext.dirs = /Library/Java/Extensions:/System/Library/Java/Extensions:/System/Library/Frameworks/JavaVM.framework/Versions/1.6.0/Home/lib/ext
[1;16:37:27.884] java.home = /System/Library/Frameworks/JavaVM.framework/Versions/1.6.0/Home
[1;16:37:27.884] java.io.tmpdir = /var/folders/zz/zzzivhrRnAmviuee+++++++++++/-Tmp-/
[1;16:37:27.884] java.library.path = .:/Library/Java/Extensions:/System/Library/Java/Extensions:/usr/lib/java
[1;16:37:27.884] java.rmi.server.codebase = file:./lib/server.jar
[1;16:37:27.884] java.rmi.server.hostname = 192.168.2.12
[1;16:37:27.884] java.runtime.name = Java(TM) SE Runtime Environment
[1;16:37:27.884] java.runtime.version = 1.6.0_20-b02-279-10M3065
[1;16:37:27.885] java.security.policy = java.policy
[1;16:37:27.885] java.specification.name = Java Platform API Specification
[1;16:37:27.885] java.specification.vendor = Sun Microsystems Inc.
[1;16:37:27.885] java.specification.version = 1.6
[1;16:37:27.885] java.vendor = Apple Inc.
[1;16:37:27.885] java.vendor.url = http://www.apple.com/
[1;16:37:27.885] java.vendor.url.bug = http://bugreport.apple.com/
[1;16:37:27.885] java.version = 1.6.0_20
[1;16:37:27.885] java.vm.info = mixed mode
[1;16:37:27.886] java.vm.name = Java HotSpot(TM) Client VM
[1;16:37:27.886] java.vm.specification.name = Java Virtual Machine Specification
[1;16:37:27.886] java.vm.specification.vendor = Sun Microsystems Inc.
[1;16:37:27.886] java.vm.specification.version = 1.0
[1;16:37:27.886] java.vm.vendor = Apple Inc.
[1;16:37:27.886] java.vm.version = 16.3-b01-279
[1;16:37:27.886] line.separator =
[1;16:37:27.887] mrj.build = 10M3065
[1;16:37:27.887] mrj.version = 1060.1.6.0_20-279
[1;16:37:27.887] os.arch = i386
[1;16:37:27.887] os.name = Mac OS X
[1;16:37:27.887] os.version = 10.6.4
[1;16:37:27.887] path.separator = :
[1;16:37:27.887] reg.code = 5P61-5C3I-TFUX-7O7K-K0J3-0SQ9-QZ4F-0VX7
[1;16:37:27.887] reg.user = Jason - Apartment11
[1;16:37:27.888] socksNonProxyHosts = local|*.local|169.254/16|*.169.254/16
[1;16:37:27.888] sun.arch.data.model = 32
[1;16:37:27.888] sun.boot.class.path = /System/Library/Frameworks/JavaVM.framework/Versions/1.6.0/Classes/jsfd.jar:/System/Library/Frameworks/JavaVM.framework/Versions/1.6.0/Classes/classes.jar:/System/Library/Frameworks/JavaVM.framework/Frameworks/JavaRuntimeSupport.framework/Resources/Java/JavaRuntimeSupport.jar:/System/Library/Frameworks/JavaVM.framework/Versions/1.6.0/Classes/ui.jar:/System/Library/Frameworks/JavaVM.framework/Versions/1.6.0/Classes/laf.jar:/System/Library/Frameworks/JavaVM.framework/Versions/1.6.0/Classes/sunrsasign.jar:/System/Library/Frameworks/JavaVM.framework/Versions/1.6.0/Classes/jsse.jar:/System/Library/Frameworks/JavaVM.framework/Versions/1.6.0/Classes/jce.jar:/System/Library/Frameworks/JavaVM.framework/Versions/1.6.0/Classes/charsets.jar
[1;16:37:27.888] sun.boot.library.path = /System/Library/Frameworks/JavaVM.framework/Versions/1.6.0/Libraries
[1;16:37:27.888] sun.cpu.endian = little
[1;16:37:27.888] sun.cpu.isalist =
[1;16:37:27.889] sun.io.unicode.encoding = UnicodeLittle
[1;16:37:27.889] sun.java.launcher = SUN_STANDARD
[1;16:37:27.889] sun.jnu.encoding = MacRoman
[1;16:37:27.889] sun.management.compiler = HotSpot Client Compiler
[1;16:37:27.889] sun.os.patch.level = unknown
[1;16:37:27.889] timestamp.format = 19
[1;16:37:27.889] user.country = US
[1;16:37:27.889] user.dir = /usr/local/catdvServer
[1;16:37:27.890] user.home = /var/root
[1;16:37:27.890] user.language = en
[1;16:37:27.890] user.name = root
[1;16:37:27.890] user.timezone = America/Los_Angeles
[1;16:37:27.890] Max memory 1520435200
[1;16:37:28.261] //localhost:1099/CatDVServer bound in registry
[1;16:37:28.262] Server will appear on 192.168.2.12
[1;16:37:28.262] Connecting to db, autocommit=false
[1;16:37:28.776] Connect (id=-1, numClips=-1) root@console @ hermans-mac-mini.local
[1;16:37:28.796] Starting server "CatDV Server 6.6b6 (Workgroup)" (id=-1, numClips=-1) root@console @ hermans-mac-mini.local
[1;16:37:28.812] Starting server "5 catalogs, 9.5 MB" (id=-1, numClips=-1) root@console @ hermans-mac-mini.local
[1;16:37:28.814] ***********************************************************************************
[1;16:37:28.814] ******** WARNING: CatDV Server was not shut down / started up properly!! ********
[1;16:37:28.814] Error: Start server "Server wasn't shut down/started up properly" (id=-1, numClips=-1) root@console @ hermans-mac-mini.local
[1;16:37:28.827] Database: MySQL 5.5.16-log
Driver: mysql-connector-java-3.1.12
Instances: 1
Database Size: 9.5 MB
Catalogs: 5 (0MB)
Clips: 612 (0MB), recycle bin: 105
Clip Usages: 6 (0MB)
User Data: 462 (0MB)
Tapes: 0 (0MB)
Thumbnails: 2313 (8MB)
SourceMedias: 600 (0MB)
ImportSources: 598 (0MB)
Audit Log: 714 (0MB)
Max ID: 5076
DB Schema: 3.21
Running: hermans-mac-mini.local
[1;16:37:28.828] Performing housekeeping...
[1;16:37:28.832] Cleaned 0 old clips from recycle bin
[1;16:37:28.848] Cleaned 0 unreferenced clips
[1;16:37:28.850] Cleaned 0 blank user data items
[1;16:37:28.853] Cleaned 0 unreferenced user data items
[1;16:37:28.862] Cleaned 0 unreferenced import sources
[1;16:37:28.863] Cleaned 0 unreferenced clip usages
[1;16:37:28.874] Cleaned 0 unreferenced source media refs
[1;16:37:28.920] Cleaned 0 unreferenced thumbnails
[1;16:37:28.921] Cleaned 0 unreferenced metaclip members
[1;16:37:28.921] Housekeeping "Nothing to do" (id=-1, numClips=0) root@console @ hermans-mac-mini.local
[1;16:37:28.923] Nothing to do
[1;16:37:28.926] Starting server "Running on 192.168.2.12:1099" (id=-1, numClips=-1) root@console @ hermans-mac-mini.local
[16;16:38:12.675] Shutting down server, signalled via shutdown hook
[16;16:38:12.720] ===== Shutdown commencing at Sat Oct 22 16:38:12 PDT 2011 (requested by null) =====
[16;16:38:12.721] Shutting down repository
[16;16:38:12.758] ======== SQL Exception ========
[16;16:38:12.758] err=com.mysql.jdbc.CommunicationsException: Communications link failure due to underlying exception:
** BEGIN NESTED EXCEPTION **
java.io.EOFException
STACKTRACE:
at com.mysql.jdbc.MysqlIO.readFully(MysqlIO.java:1905)
at com.mysql.jdbc.MysqlIO.reuseAndReadPacket(MysqlIO.java:2351)
at com.mysql.jdbc.MysqlIO.checkErrorPacket(MysqlIO.java:2862)
at com.mysql.jdbc.MysqlIO.sendCommand(MysqlIO.java:1571)
at com.mysql.jdbc.MysqlIO.sqlQueryDirect(MysqlIO.java:1666)
at com.mysql.jdbc.Connection.execSQL(Connection.java:2988)
at com.mysql.jdbc.Connection.execSQL(Connection.java:2917)
at com.mysql.jdbc.Statement.executeQuery(Statement.java:824)
at squarebox.catdv.server.sql.SQLRepository.getShortStats(Unknown Source)
at squarebox.catdv.server.sql.SQLDelegate.shutdownChecks(Unknown Source)
at squarebox.catdv.server.CatDVServer.$1(Unknown Source)
at squarebox.catdv.server.CatDVServer.access$100(Unknown Source)
** END NESTED EXCEPTION **
Last packet sent to the server was 37 ms ago.
[16;16:38:12.759] op=getShortStats code=0 state=08S01 next=null
[16;16:38:12.759] Rollback failed: java.sql.SQLException: No operations allowed after connection closed.Connection was implicitly closed due to underlying exception/error:
MESSAGE: Communications link failure due to underlying exception:
STACKTRACE:
STACKTRACE:
STACKTRACE:
at com.mysql.jdbc.MysqlIO.reuseAndReadPacket(MysqlIO.java:2563)
[16;16:38:12.759] ===============================
[16;16:38:12.759] com.mysql.jdbc.CommunicationsException: Communications link failure due to underlying exception:
STACKTRACE:
[16;16:38:12.759] at com.mysql.jdbc.MysqlIO.reuseAndReadPacket(MysqlIO.java:2563)
[16;16:38:12.760] at com.mysql.jdbc.MysqlIO.checkErrorPacket(MysqlIO.java:2862)
[16;16:38:12.760] at com.mysql.jdbc.MysqlIO.sendCommand(MysqlIO.java:1571)
[16;16:38:12.760] at com.mysql.jdbc.MysqlIO.sqlQueryDirect(MysqlIO.java:1666)
[16;16:38:12.760] at com.mysql.jdbc.Connection.execSQL(Connection.java:2988)
[16;16:38:12.760] at com.mysql.jdbc.Connection.execSQL(Connection.java:2917)
[16;16:38:12.760] at com.mysql.jdbc.Statement.executeQuery(Statement.java:824)
[16;16:38:12.760] at squarebox.catdv.server.sql.SQLRepository.getShortStats(Unknown Source)
[16;16:38:12.760] at squarebox.catdv.server.sql.SQLDelegate.shutdownChecks(Unknown Source)
[16;16:38:12.760] at squarebox.catdv.server.CatDVServer.$1(Unknown Source)
[16;16:38:12.760] at squarebox.catdv.server.CatDVServer.access$100(Unknown Source)
[16;16:38:12.761] at squarebox.catdv.server.CatDVServer$$0.run(Unknown Source)
[16;16:38:12.761] Error: getShortStats "Communications link failure due to underlying exception:
STACKTRACE:
Last packet sent to the server was 37 ms ago." (id=-1, numClips=-1) root@console @ hermans-mac-mini.local
[16;16:38:12.761] ** Failed to log event: java.sql.SQLException: No operations allowed after connection closed.Connection was implicitly closed due to underlying exception/error:
STACKTRACE:
STACKTRACE:
STACKTRACE:
[16;16:38:12.761] Stopping server (id=-1, numClips=-1) root@console @ hermans-mac-mini.local
[16;16:38:12.762] ** Failed to log event: java.sql.SQLException: No operations allowed after connection closed.Connection was implicitly closed due to underlying exception/error:
STACKTRACE:
STACKTRACE:
STACKTRACE:
[16;16:38:12.762] Clean recycle bin...
[16;16:38:12.762] ======== SQL Exception ========
[16;16:38:12.762] err=java.sql.SQLException: No operations allowed after connection closed.Connection was implicitly closed due to underlying exception/error:
STACKTRACE:
STACKTRACE:
STACKTRACE:
[16;16:38:12.762] op=cleanRecycleBin code=0 state=08003 next=null
[16;16:38:12.763] Rollback failed: java.sql.SQLException: No operations allowed after connection closed.Connection was implicitly closed due to underlying exception/error:
STACKTRACE:
STACKTRACE:
STACKTRACE:
[16;16:38:12.763] ===============================
[16;16:38:12.763] java.sql.SQLException: No operations allowed after connection closed.Connection was implicitly closed due to underlying exception/error:
STACKTRACE:
STACKTRACE:
STACKTRACE:
[16;16:38:12.763] at com.mysql.jdbc.Connection.checkClosed(Connection.java:1842)
[16;16:38:12.763] at com.mysql.jdbc.Connection.createStatement(Connection.java:2840)
[16;16:38:12.763] at com.mysql.jdbc.Connection.createStatement(Connection.java:2822)
[16;16:38:12.763] at squarebox.catdv.server.sql.SQLRepository.cleanRecycleBin(Unknown Source)
[16;16:38:12.764] at squarebox.catdv.server.sql.SQLDelegate.shutdownChecks(Unknown Source)
[16;16:38:12.764] at squarebox.catdv.server.CatDVServer.$1(Unknown Source)
[16;16:38:12.764] at squarebox.catdv.server.CatDVServer.access$100(Unknown Source)
[16;16:38:12.764] at squarebox.catdv.server.CatDVServer$$0.run(Unknown Source)
[16;16:38:12.764] Error: cleanRecycleBin "No operations allowed after connection closed.Connection was implicitly closed due to underlying exception/error:
STACKTRACE:
STACKTRACE:
STACKTRACE:
[16;16:38:12.764] ** Failed to log event: java.sql.SQLException: No operations allowed after connection closed.Connection was implicitly closed due to underlying exception/error:
STACKTRACE:
STACKTRACE:
STACKTRACE:
[16;16:38:12.765] java.lang.RuntimeException: cleanRecycleBin failed (No operations allowed after connection closed.Connection was implicitly closed due to underlying exception/error:
STACKTRACE:
STACKTRACE:
STACKTRACE:
[16;16:38:12.765] at squarebox.catdv.server.sql.SQLRepository.reportError(Unknown Source)
[16;16:38:12.765] at squarebox.catdv.server.sql.SQLRepository.cleanRecycleBin(Unknown Source)
[16;16:38:12.765] at squarebox.catdv.server.sql.SQLDelegate.shutdownChecks(Unknown Source)
[16;16:38:12.765] at squarebox.catdv.server.CatDVServer.$1(Unknown Source)
[16;16:38:12.765] at squarebox.catdv.server.CatDVServer.access$100(Unknown Source)
[16;16:38:12.765] at squarebox.catdv.server.CatDVServer$$0.run(Unknown Source)
[16;16:38:12.765] ===== Shutdown complete at Sat Oct 22 16:38:12 PDT 2011 =====
[1;16:56:04.030]
===== Starting at Oct 22, 2011 16:56:04 =====
[1;16:56:04.031] CatDV Server 6.6b6
[1;16:56:04.032] Loading properties file : catdv.properties
[1;16:56:04.032] Creating RMI Registry on port 1099
[1;16:56:04.219] awt.nativeDoubleBuffering = true
[1;16:56:04.220] awt.toolkit = apple.awt.CToolkit
[1;16:56:04.220] catdv.allowAnonymous = true
[1;16:56:04.220] catdv.database = jdbc:mysql://localhost/catdv?user=catdv&password=catdv
[1;16:56:04.220] catdv.extraDetails = false
[1;16:56:04.220] catdv.housekeeping = true
[1;16:56:04.220] catdv.rmiport = 1099
[1;16:56:04.220] catdv.useRecycleBin = true
[1;16:56:04.220] catdv.useRoles = true
[1;16:56:04.220] catdv.webDownloads = false
[1;16:56:04.221] file.encoding = MacRoman
[1;16:56:04.226] file.encoding.pkg = sun.io
[1;16:56:04.226] file.separator = /
[1;16:56:04.227] ftp.nonProxyHosts = local|*.local|169.254/16|*.169.254/16
[1;16:56:04.227] gopherProxySet = false
[1;16:56:04.227] http.nonProxyHosts = local|*.local|169.254/16|*.169.254/16
[1;16:56:04.227] java.awt.graphicsenv = apple.awt.CGraphicsEnvironment
[1;16:56:04.227] java.awt.printerjob = apple.awt.CPrinterJob
[1;16:56:04.227] java.class.path = lib/server.jar:lib/jaxp.jar:lib/parser.jar:lib/jakarta-regexp-1.2.jar:lib/mm.mysql-2.0.14-bin.jar:lib/mysql-connector-java-3.1.12-bin.jar
[1;16:56:04.228] java.class.version = 50.0
[1;16:56:04.228] java.endorsed.dirs = /System/Library/Frameworks/JavaVM.framework/Versions/1.6.0/Home/lib/endorsed
[1;16:56:04.228] java.ext.dirs = /Library/Java/Extensions:/System/Library/Java/Extensions:/System/Library/Frameworks/JavaVM.framework/Versions/1.6.0/Home/lib/ext
[1;16:56:04.228] java.home = /System/Library/Frameworks/JavaVM.framework/Versions/1.6.0/Home
[1;16:56:04.228] java.io.tmpdir = /var/folders/zz/zzzivhrRnAmviuee+++++++++++/-Tmp-/
[1;16:56:04.228] java.library.path = .:/Library/Java/Extensions:/System/Library/Java/Extensions:/usr/lib/java
[1;16:56:04.228] java.rmi.server.codebase = file:./lib/server.jar
[1;16:56:04.229] java.rmi.server.hostname = 192.168.2.12
[1;16:56:04.229] java.runtime.name = Java(TM) SE Runtime Environment
[1;16:56:04.229] java.runtime.version = 1.6.0_20-b02-279-10M3065
[1;16:56:04.229] java.security.policy = java.policy
[1;16:56:04.229] java.specification.name = Java Platform API Specification
[1;16:56:04.229] java.specification.vendor = Sun Microsystems Inc.
[1;16:56:04.229] java.specification.version = 1.6
[1;16:56:04.229] java.vendor = Apple Inc.
[1;16:56:04.230] java.vendor.url = http://www.apple.com/
[1;16:56:04.230] java.vendor.url.bug = http://bugreport.apple.com/
[1;16:56:04.230] java.version = 1.6.0_20
[1;16:56:04.230] java.vm.info = mixed mode
[1;16:56:04.230] java.vm.name = Java HotSpot(TM) Client VM
[1;16:56:04.230] java.vm.specification.name = Java Virtual Machine Specification
[1;16:56:04.230] java.vm.specification.vendor = Sun Microsystems Inc.
[1;16:56:04.231] java.vm.specification.version = 1.0
[1;16:56:04.231] java.vm.vendor = Apple Inc.
[1;16:56:04.231] java.vm.version = 16.3-b01-279
[1;16:56:04.231] line.separator =
[1;16:56:04.231] mrj.build = 10M3065
[1;16:56:04.231] mrj.version = 1060.1.6.0_20-279
[1;16:56:04.231] os.arch = i386
[1;16:56:04.231] os.name = Mac OS X
[1;16:56:04.231] os.version = 10.6.4
[1;16:56:04.232] path.separator = :
[1;16:56:04.232] reg.code = 5P61-5C3I-TFUX-7O7K-K0J3-0SQ9-QZ4F-0VX7
[1;16:56:04.232] reg.user = Jason - Apartment11
[1;16:56:04.232] socksNonProxyHosts = local|*.local|169.254/16|*.169.254/16
[1;16:56:04.232] sun.arch.data.model = 32
[1;16:56:04.232] sun.boot.class.path = /System/Library/Frameworks/JavaVM.framework/Versions/1.6.0/Classes/jsfd.jar:/System/Library/Frameworks/JavaVM.framework/Versions/1.6.0/Classes/classes.jar:/System/Library/Frameworks/JavaVM.framework/Frameworks/JavaRuntimeSupport.framework/Resources/Java/JavaRuntimeSupport.jar:/System/Library/Frameworks/JavaVM.framework/Versions/1.6.0/Classes/ui.jar:/System/Library/Frameworks/JavaVM.framework/Versions/1.6.0/Classes/laf.jar:/System/Library/Frameworks/JavaVM.framework/Versions/1.6.0/Classes/sunrsasign.jar:/System/Library/Frameworks/JavaVM.framework/Versions/1.6.0/Classes/jsse.jar:/System/Library/Frameworks/JavaVM.framework/Versions/1.6.0/Classes/jce.jar:/System/Library/Frameworks/JavaVM.framework/Versions/1.6.0/Classes/charsets.jar
[1;16:56:04.232] sun.boot.library.path = /System/Library/Frameworks/JavaVM.framework/Versions/1.6.0/Libraries
[1;16:56:04.233] sun.cpu.endian = little
[1;16:56:04.233] sun.cpu.isalist =
[1;16:56:04.233] sun.io.unicode.encoding = UnicodeLittle
[1;16:56:04.233] sun.java.launcher = SUN_STANDARD
[1;16:56:04.233] sun.jnu.encoding = MacRoman
[1;16:56:04.233] sun.management.compiler = HotSpot Client Compiler
[1;16:56:04.233] sun.os.patch.level = unknown
[1;16:56:04.233] timestamp.format = 19
[1;16:56:04.234] user.country = US
[1;16:56:04.234] user.dir = /usr/local/catdvServer
[1;16:56:04.234] user.home = /var/root
[1;16:56:04.234] user.language = en
[1;16:56:04.234] user.name = root
[1;16:56:04.234] user.timezone = America/Los_Angeles
[1;16:56:04.234] Max memory 1520435200
[1;16:56:04.845] //localhost:1099/CatDVServer bound in registry
[1;16:56:04.846] Server will appear on 192.168.2.12
[1;16:56:04.846] Connecting to db, autocommit=false
[1;16:56:05.245] Connect (id=-1, numClips=-1) root@console @ hermans-mac-mini.local
[1;16:56:05.323] Starting server "CatDV Server 6.6b6 (Workgroup)" (id=-1, numClips=-1) root@console @ hermans-mac-mini.local
[1;16:56:05.474] Starting server "5 catalogs, 9.5 MB" (id=-1, numClips=-1) root@console @ hermans-mac-mini.local
[1;16:56:05.476] ***********************************************************************************
[1;16:56:05.476] ******** WARNING: CatDV Server was not shut down / started up properly!! ********
[1;16:56:05.477] Error: Start server "Server wasn't shut down/started up properly" (id=-1, numClips=-1) root@console @ hermans-mac-mini.local
[1;16:56:05.490] Database: MySQL 5.5.16-log
Instances: 1
Catalogs: 5 (0MB)
Tapes: 0 (0MB)
Audit Log: 720 (0MB)
Max ID: 5076
DB Schema: 3.21
[1;16:56:05.490] Performing housekeeping...
[1;16:56:05.494] Cleaned 0 old clips from recycle bin
[1;16:56:05.510] Cleaned 0 unreferenced clips
[1;16:56:05.511] Cleaned 0 blank user data items
[1;16:56:05.514] Cleaned 0 unreferenced user data items
[1;16:56:05.523] Cleaned 0 unreferenced import sources
[1;16:56:05.524] Cleaned 0 unreferenced clip usages
[1;16:56:05.537] Cleaned 0 unreferenced source media refs
[1;16:56:05.583] Cleaned 0 unreferenced thumbnails
[1;16:56:05.605] Cleaned 0 unreferenced metaclip members
[1;16:56:05.606] Housekeeping "Nothing to do" (id=-1, numClips=0) root@console @ hermans-mac-mini.local
[1;16:56:05.622] Nothing to do
[1;16:56:05.672] Starting server "Running on 192.168.2.12:1099" (id=-1, numClips=-1) root@console @ hermans-mac-mini.local
[18;17:04:43.541] Connecting to db, autocommit=false
[18;17:04:43.559] Connect (id=-1, numClips=-1) edit11 (backup) @ backups-power-mac-g5.local (192.168.2.15)
[18;17:04:43.561] Connection from edit11 (backup)@backups-power-mac-g5.local(192.168.2.15) connectionID=-1159518051 at Oct 22, 2011 17:04:43
[18;17:04:46.604] backups-power-mac-g5.local (192.168.2.15): GetCatalogs [2093K]
[18;17:04:46.765] backups-power-mac-g5.local (192.168.2.15): -> 5 catalogs [2246K]
[18;17:05:19.821] backups-power-mac-g5.local (192.168.2.15): QueryCount QueryDefinition[filterName=Catalog '10_15_2011',catalog=-1,name=null,false,moreThumbs=true] [2477K]
[18;17:05:20.062] INSERT INTO tmpClips SELECT DISTINCT clip.id, clip.modifyDate FROM clip JOIN catalog ON clip.catalogID=catalog.id WHERE catalog.id=2657 ORDER BY clip.modifyDate DESC,clip.id DESC LIMIT 5000
[18;17:05:20.068] prepare took 0.0060s
[18;17:05:20.070] backups-power-mac-g5.local (192.168.2.15): -> 96 [2477K]
[18;17:05:20.070] count took 0.248s
[18;17:05:20.077] backups-power-mac-g5.local (192.168.2.15): PerformQueryNT QueryDefinition[filterName=Catalog '10_15_2011',catalog=-1,name=null,false,moreThumbs=true] cutoff=-1 [2507K]
[18;17:05:20.137] -> 96 clips
[18;17:05:20.146] -> 1 catalogs
[18;17:05:20.210] -> 95 source medias
[18;17:05:20.252] Got 593+0+95 -> 593 thumbnails
[18;17:05:20.253] -> 593 thumbnails
[18;17:05:20.272] -> 95 import sources
[18;17:05:20.273] -> 0 events
[18;17:05:20.274] -> 0 clip usages
[18;17:05:20.275] -> 0 metaclip members
[18;17:05:20.276] backups-power-mac-g5.local (192.168.2.15): -> Query took 0.198s, 4262k in use [4262K]
[18;17:05:20.425] backups-power-mac-g5.local (192.168.2.15): GetThumbnails 593 [4710K]
[18;17:05:20.460] backups-power-mac-g5.local (192.168.2.15): -> Got 593 thumbs in 0.035s, 3766k in use [3766K]
[19;17:05:37.988] Disconnection from edit11 (backup)@backups-power-mac-g5.local(192.168.2.15)
[19;17:05:37.988] Disconnect (id=-1, numClips=-1) edit11 (backup) @ backups-power-mac-g5.local (192.168.2.15)
[458;05:38:58.471] Connecting to db, autocommit=false
[458;05:38:58.487] Connect (id=-1, numClips=-1) jason levy (edit15) @ jasons-Mac-mini.local (192.168.2.20)
[458;05:38:58.489] Connection from jason levy (edit15)@jasons-Mac-mini.local(192.168.2.20) connectionID=-1947860308 at Oct 24, 2011 05:38:58
[458;05:39:05.847] jasons-Mac-mini.local (192.168.2.20): GetCatalogs [1489K]
[458;05:39:05.914] jasons-Mac-mini.local (192.168.2.20): -> 5 catalogs [1597K]
[458;05:39:09.075] jasons-Mac-mini.local (192.168.2.20): QueryCount QueryDefinition[filterName=null,catalog=1489,name=null,true,moreThumbs=true] [1705K]
[458;05:39:09.078] INSERT INTO tmpClips SELECT clip.id, clip.modifyDate FROM clip,catalog WHERE clip.catalogID=catalog.ID AND catalog.ID=1489
[458;05:39:09.092] jasons-Mac-mini.local (192.168.2.20): -> 186 [1723K]
[458;05:39:09.092] count took 0.017s
[458;05:39:09.096] jasons-Mac-mini.local (192.168.2.20): PerformQueryNTZ QueryDefinition[filterName=null,catalog=1489,name=null,true,moreThumbs=true] cutoff=-1 [1741K]
[458;05:39:09.150] -> 186 clips
[458;05:39:09.163] -> 1 catalogs
[458;05:39:09.294] -> 186 source medias
[458;05:39:09.344] Got 582+0+186 -> 582 thumbnails
[458;05:39:09.344] -> 582 thumbnails
[458;05:39:09.378] -> 186 import sources
[458;05:39:09.381] -> 0 events
[458;05:39:09.382] -> 0 clip usages
[458;05:39:09.383] -> 0 metaclip members
[458;05:39:09.383] jasons-Mac-mini.local (192.168.2.20): -> Query took 0.286s, 4189k in use [4189K]
[458;05:39:09.511] jasons-Mac-mini.local (192.168.2.20): -> Compressed to 78K in 0.128s, 4189k in use [2417K]
[459;05:39:09.589] jasons-Mac-mini.local (192.168.2.20): GetThumbnails 582 [2486K]
[459;05:39:09.614] jasons-Mac-mini.local (192.168.2.20): -> Got 582 thumbs in 0.024s, 4490k in use [4490K]
[459;05:40:09.534] jasons-Mac-mini.local (192.168.2.20): pollServerZ took 3ms -> 758 bytes [4739K]
[459;05:40:09.543] jasons-Mac-mini.local (192.168.2.20): FindCatalogs QueryDefinition[filterName=10_12_2011,catalog=1489,name=null,true,moreThumbs=true] [4757K]
[459;05:40:09.544] jasons-Mac-mini.local (192.168.2.20): -> 1 catalogs [4775K]
[459;05:40:09.550] jasons-Mac-mini.local (192.168.2.20): GetCatalogs [4793K]
[459;05:40:09.684] jasons-Mac-mini.local (192.168.2.20): -> 5 catalogs [4883K]
[460;05:45:24.571] Re-connecting to db after idle connection
[460;05:45:24.585] jasons-Mac-mini.local (192.168.2.20): pollServerZ took 14ms -> 758 bytes [5411K]
[460;05:45:24.594] jasons-Mac-mini.local (192.168.2.20): FindCatalogs QueryDefinition[filterName=10_12_2011,catalog=1489,name=null,true,moreThumbs=true] [5447K]
[460;05:45:24.594] jasons-Mac-mini.local (192.168.2.20): -> 1 catalogs [5447K]
[461;05:50:39.597] Re-connecting to db after idle connection
[461;05:50:39.611] jasons-Mac-mini.local (192.168.2.20): pollServerZ took 14ms -> 758 bytes [5958K]
[461;05:50:39.616] jasons-Mac-mini.local (192.168.2.20): FindCatalogs QueryDefinition[filterName=10_12_2011,catalog=1489,name=null,true,moreThumbs=true] [5994K]
[461;05:50:39.617] jasons-Mac-mini.local (192.168.2.20): -> 1 catalogs [5994K]
[463;05:52:54.271] Connecting to db, autocommit=false
[463;05:52:54.283] Connect (id=-1, numClips=-1) Apple Events User (user) @ toshiba-lp3.apt11.lan (192.168.2.19)
[463;05:52:54.285] Connection from Apple Events User (user)@toshiba-lp3.apt11.lan(192.168.2.19) connectionID=1138056698 at Oct 24, 2011 05:52:54
[466;05:55:35.403] A client has reconnected without disconnecting. The old connection has been terminated:
User Apple Events User (user), connected from toshiba-lp3.apt11.lan (192.168.2.19), idle for 161s
[466;05:55:35.404] Connecting to db, autocommit=false
[466;05:55:35.415] Connect (id=-1, numClips=-1) Apple Events User (user) @ toshiba-lp3.apt11.lan (192.168.2.19)
[466;05:55:35.417] Connection from Apple Events User (user)@toshiba-lp3.apt11.lan(192.168.2.19) connectionID=1138217830 at Oct 24, 2011 05:55:35
[467;05:55:38.224] toshiba-lp3.apt11.lan (192.168.2.19): GetCatalogs [2122K]
[467;05:55:38.292] toshiba-lp3.apt11.lan (192.168.2.19): -> 5 catalogs [2213K]
[468;05:56:16.438] Re-connecting to db after idle connection
[470;05:58:02.729] Disconnection from Apple Events User (user)@toshiba-lp3.apt11.lan(192.168.2.19)
[470;05:58:02.730] Disconnect (id=-1, numClips=-1) Apple Events User (user) @ toshiba-lp3.apt11.lan (192.168.2.19)
[470;05:58:12.216] Connecting to db, autocommit=false
[470;05:58:12.233] Connect (id=-1, numClips=-1) Apple Events User (user) @ toshiba-lp3.apt11.lan (192.168.2.21)
[470;05:58:12.235] Connection from Apple Events User (user)@toshiba-lp3.apt11.lan(192.168.2.21) connectionID=1138374644 at Oct 24, 2011 05:58:12
[470;05:58:15.276] toshiba-lp3.apt11.lan (192.168.2.21): GetCatalogs [2142K]
[470;05:58:15.578] Extra details for 5 catalogs took 301ms
[470;05:58:15.578] toshiba-lp3.apt11.lan (192.168.2.21): -> 5 catalogs [2232K]
[471;05:59:16.508] toshiba-lp3.apt11.lan (192.168.2.21): GetCatalogs [1457K]
[471;05:59:16.815] Extra details for 5 catalogs took 306ms
[471;05:59:16.816] toshiba-lp3.apt11.lan (192.168.2.21): -> 5 catalogs [1548K]
[467;05:59:45.269] Disconnection from Apple Events User (user)@toshiba-lp3.apt11.lan(192.168.2.21)
[467;05:59:45.269] Disconnect (id=-1, numClips=-1) Apple Events User (user) @ toshiba-lp3.apt11.lan (192.168.2.21)
[473;06:05:05.999] Connecting to db, autocommit=false
[473;06:05:06.011] Connect (id=-1, numClips=-1) edit10 (apt11) @ Audio-Vanya.local (192.168.2.14)
[473;06:05:06.012] Connection from edit10 (apt11)@Audio-Vanya.local(192.168.2.14) connectionID=250263870 at Oct 24, 2011 06:05:06
[473;06:06:22.738] Audio-Vanya.local (192.168.2.14): GetCatalogs [2058K]
[473;06:06:23.058] Extra details for 5 catalogs took 319ms
[473;06:06:23.058] Audio-Vanya.local (192.168.2.14): -> 5 catalogs [2170K]
[474;06:06:30.759] Audio-Vanya.local (192.168.2.14): QueryCount QueryDefinition[filterName=Catalog '10_16_2011',catalog=-1,name=null,false,moreThumbs=true] [2337K]
[474;06:06:30.832] INSERT INTO tmpClips SELECT DISTINCT clip.id, clip.modifyDate FROM clip JOIN catalog ON clip.catalogID=catalog.id WHERE catalog.id=3552 ORDER BY clip.modifyDate DESC,clip.id DESC LIMIT 5000
[474;06:06:30.842] prepare took 0.01s
[474;06:06:30.844] Audio-Vanya.local (192.168.2.14): -> 198 [2337K]
[474;06:06:30.845] count took 0.085s
[474;06:06:30.851] Audio-Vanya.local (192.168.2.14): PerformQueryNT QueryDefinition[filterName=Catalog '10_16_2011',catalog=-1,name=null,false,moreThumbs=true] cutoff=-1 [2374K]
[474;06:06:30.907] -> 198 clips
[474;06:06:30.920] -> 1 catalogs
[474;06:06:31.132] -> 198 source medias
[474;06:06:31.179] Got 534+0+198 -> 534 thumbnails
[474;06:06:31.179] -> 534 thumbnails
[474;06:06:31.213] -> 198 import sources
[474;06:06:31.214] -> 0 events
[474;06:06:31.215] -> 0 clip usages
[474;06:06:31.216] -> 0 metaclip members
[474;06:06:31.216] Audio-Vanya.local (192.168.2.14): -> Query took 0.365s, 4758k in use [4758K]
[474;06:06:31.335] Audio-Vanya.local (192.168.2.14): GetThumbnails 534 [5257K]
[474;06:06:31.357] Audio-Vanya.local (192.168.2.14): -> Got 534 thumbs in 0.021s, 3511k in use [3511K]
[475;06:06:36.697] Connecting to db, autocommit=false
[475;06:06:36.710] Connect (id=-1, numClips=-1) edit11 (backup) @ backups-power-mac-g5.local (192.168.2.15)
[475;06:06:36.712] Connection from edit11 (backup)@backups-power-mac-g5.local(192.168.2.15) connectionID=-1026204890 at Oct 24, 2011 06:06:36
[475;06:06:40.767] backups-power-mac-g5.local (192.168.2.15): GetCatalogs [2232K]
[475;06:06:40.911] backups-power-mac-g5.local (192.168.2.15): -> 5 catalogs [2322K]
[476;06:06:41.234] Audio-Vanya.local (192.168.2.14): QueryCount QueryDefinition[filterName=Catalog '10_16_2011',catalog=3552,name=null,true,moreThumbs=true] [2474K]
[476;06:06:41.243] INSERT INTO tmpClips SELECT clip.id, clip.modifyDate FROM clip,catalog WHERE clip.catalogID=catalog.ID AND catalog.ID=3552
[476;06:06:41.268] Audio-Vanya.local (192.168.2.14): -> 198 [2547K]
[476;06:06:41.269] count took 0.035s
[476;06:06:41.273] Audio-Vanya.local (192.168.2.14): PerformQueryNT QueryDefinition[filterName=Catalog '10_16_2011',catalog=3552,name=null,true,moreThumbs=true] cutoff=1319230909517 [2582K]
[476;06:06:41.280] -> 0+198 clips
[476;06:06:41.283] -> 1 catalogs
[476;06:06:41.338] -> 0 source medias
[476;06:06:41.342] Got 0+0+0 -> 0 thumbnails
[476;06:06:41.342] -> 0 thumbnails
[476;06:06:41.345] -> 0 import sources
[476;06:06:41.348] -> 0 events
[476;06:06:41.349] -> 0 clip usages
[476;06:06:41.350] -> 0 metaclip members
[476;06:06:41.350] Audio-Vanya.local (192.168.2.14): -> Query took 0.077s, 2737k in use [2737K]
[475;06:06:42.405] backups-power-mac-g5.local (192.168.2.15): QueryCount QueryDefinition[filterName=Catalog '10_16_2011',catalog=-1,name=null,false,moreThumbs=true] [2925K]
[475;06:06:42.408] INSERT INTO tmpClips SELECT DISTINCT clip.id, clip.modifyDate FROM clip JOIN catalog ON clip.catalogID=catalog.id WHERE catalog.id=3552 ORDER BY clip.modifyDate DESC,clip.id DESC LIMIT 5000
[475;06:06:42.419] prepare took 0.011s
[475;06:06:42.421] backups-power-mac-g5.local (192.168.2.15): -> 198 [2940K]
[475;06:06:42.421] count took 0.016s
[475;06:06:42.429] backups-power-mac-g5.local (192.168.2.15): PerformQueryNT QueryDefinition[filterName=Catalog '10_16_2011',catalog=-1,name=null,false,moreThumbs=true] cutoff=-1 [2970K]
[475;06:06:42.481] -> 198 clips
[475;06:06:42.494] -> 1 catalogs
[475;06:06:42.604] -> 198 source medias
[475;06:06:42.650] Got 534+0+198 -> 534 thumbnails
[475;06:06:42.650] -> 534 thumbnails
[475;06:06:42.684] -> 198 import sources
[475;06:06:42.685] -> 0 events
[475;06:06:42.686] -> 0 clip usages
[475;06:06:42.687] -> 0 metaclip members
[475;06:06:42.687] backups-power-mac-g5.local (192.168.2.15): -> Query took 0.258s, 5348k in use [5348K]
[475;06:06:42.855] backups-power-mac-g5.local (192.168.2.15): GetThumbnails 534 [5728K]
[475;06:06:42.876] backups-power-mac-g5.local (192.168.2.15): -> Got 534 thumbs in 0.021s, 3889k in use [3889K]
[475;06:06:46.232] backups-power-mac-g5.local (192.168.2.15): QueryCount QueryDefinition[filterName=Catalog '10_16_2011',catalog=3552,name=null,true,moreThumbs=true] [3984K]
[475;06:06:46.236] INSERT INTO tmpClips SELECT clip.id, clip.modifyDate FROM clip,catalog WHERE clip.catalogID=catalog.ID AND catalog.ID=3552
[475;06:06:46.266] backups-power-mac-g5.local (192.168.2.15): -> 198 [4023K]
[475;06:06:46.266] count took 0.033s
[475;06:06:46.274] backups-power-mac-g5.local (192.168.2.15): PerformQueryNT QueryDefinition[filterName=Catalog '10_16_2011',catalog=3552,name=null,true,moreThumbs=true] cutoff=1319230909517 [4023K]
[475;06:06:46.280] -> 0+198 clips
[475;06:06:46.284] -> 1 catalogs
[475;06:06:46.310] -> 0 source medias
[475;06:06:46.314] Got 0+0+0 -> 0 thumbnails
[475;06:06:46.314] -> 0 thumbnails
[475;06:06:46.316] -> 0 import sources
[475;06:06:46.318] -> 0 events
[475;06:06:46.320] -> 0 clip usages
[475;06:06:46.320] -> 0 metaclip members
[475;06:06:46.320] backups-power-mac-g5.local (192.168.2.15): -> Query took 0.046s, 4223k in use [4223K]
[476;06:07:23.184] Re-connecting to db after idle connection
[476;06:07:23.197] jasons-Mac-mini.local (192.168.2.20): pollServerZ took 13ms -> 758 bytes [4656K]
[476;06:07:23.202] jasons-Mac-mini.local (192.168.2.20): FindCatalogs QueryDefinition[filterName=10_12_2011,catalog=1489,name=null,true,moreThumbs=true] [4684K]
[476;06:07:23.203] jasons-Mac-mini.local (192.168.2.20): -> 1 catalogs [4684K]
[476;06:07:23.207] jasons-Mac-mini.local (192.168.2.20): GetCatalogs [4698K]
[476;06:07:23.274] jasons-Mac-mini.local (192.168.2.20): -> 5 catalogs [4794K]
[477;06:09:29.858] Audio-Vanya.local (192.168.2.14): pollServerZ took 1ms -> 758 bytes [4961K]
[477;06:09:29.894] Audio-Vanya.local (192.168.2.14): GetCatalogs [4976K]
[477;06:09:30.198] Extra details for 5 catalogs took 303ms
[477;06:09:30.198] Audio-Vanya.local (192.168.2.14): -> 5 catalogs [5067K]
[477;06:09:30.223] Audio-Vanya.local (192.168.2.14): FindCatalogs QueryDefinition[filterName=Catalog '10_16_2011',catalog=3552,name=null,true,moreThumbs=true] [5097K]
[477;06:09:30.224] Audio-Vanya.local (192.168.2.14): -> 1 catalogs [5112K]
[478;06:11:28.592] backups-power-mac-g5.local (192.168.2.15): pollServerZ took 2ms -> 758 bytes [5339K]
[478;06:11:28.623] backups-power-mac-g5.local (192.168.2.15): FindCatalogs QueryDefinition[filterName=Catalog '10_16_2011',catalog=3552,name=null,true,moreThumbs=true] [5354K]
[478;06:11:28.624] backups
jason levy
on Oct 24, 2011 at 3:50:39 pm
actually several computers do not connect. Could it be the Java version?
jason levy
Figured it out.. no jumbo frames allowed
on Oct 24, 2011 at 5:27:02 pm
We are using a Final Share ethernet SAN and we enable jumbo frames on the macs that will do that because it is less load on the server..
however Jumbo frames will prevent proper communication with the Cat DV server.
jason
Rolf Howarth
Re: Figured it out.. no jumbo frames allowed
on Oct 25, 2011 at 10:21:14 pm
That's great to hear, thanks for letting us know!
bryson jones
on Oct 25, 2011 at 10:31:31 pm
Thank you! And that's a hard one I'd have chased it forever.
bryson
hidefcowboy.com
jason levy
on Oct 30, 2011 at 5:00:34 pm
Anyhow Bob Zelin tells me that enabling jumbo frames is of no use anyhow... unless they are enabled on every component of the system.. live and learn.
