Worker multiple cmds with variables
COW Forums : Square Box CatDV
John Heagy
on Oct 17, 2011 at 9:51:58 pm
How do I run multiple commands in Post-Processing? If I type two commands in line separated by a comma (xxx, xxx) it ignores the second command and uses the (,). If I make a .sh with the comma separated commands the variables are not respected.
John
Rolf Howarth
Re: Worker multiple cmds with variables
on Oct 17, 2011 at 10:33:26 pm
You might be able to do something like
/bin/sh -c "command1; command2"
but I haven't tried it. The best thing is probably to write a shell script that executes the two commands you want, passing your arguments to the shell script and then referring to them as $1, $2 etc. in the shell script.
John Heagy
on Oct 17, 2011 at 10:56:13 pm
Hi Rolf,
I can get two commands to run in a shell script but the CatDV variables are ignored. Are you suggesting I set the variables somehow 1st? Wouldn't that require yet another command?
I did manage to do what I wanted by using the 1st execute command in "Conversions" then the 3rd in Post-Processing"
Doing it via a shell script would be great if the CatDV variables expanded.
John
Rolf Howarth
on Oct 18, 2011 at 7:38:30 am
Where are you writing the CatDV variables such as ${U1}? That syntax is only understood on the command line itself, it won't work within the shell script.
Command 1: myscript.sh
Then a s shell script that contains the following WON'T work:
#!/bin/sh
echo User1 = ${U1}
Instead, you need to do
Command 1: myscript.sh ${U1}
#!/bin/sh
echo User1 = $1
