How to log into web-client?
COW Forums : Square Box CatDV
Henrik Helms
on Oct 14, 2011 at 7:46:05 am
Hi!
I am using CatDV workgroup along with the web-client and worker node.
After setting up the client it asks me for username and password. In the manual it says that I can set this up in the server admin panel. But this is only possible if I have the enterprise module. What can I do in workgroup? I have tried all my known passwords, ip addresses and so... and are not able to login....
Kind regards
Henrik
dBA MEDIA
Rolf Howarth
Re: How to log into web-client?
on Oct 14, 2011 at 9:53:35 am
The web client isn't really designed to be used with the workgroup server as being able to log on is one of the main features of the web client compared to the older Live HTML Publisher. You should be able to use the two together if you check the allow anonymous access option on the server control panel and then just press cancel in the log on dialog of the web client.
