Multiple Ins and and outs?
COW Forums : Square Box CatDV
Scott Coulter
on Aug 22, 2011 at 6:56:55 pm
I'm just wondering, is it possible to have multiple ins and outs on a single clip? I'm guessing (if it works) it will just be split up into multiple versions of the same clip. Thanks!
bryson jones
Re: Multiple Ins and and outs?
on Aug 22, 2011 at 7:16:16 pm
Not to my knowledge. The process would be to create subclips and use those.
Although you could use "range" markers in the event marker's area as that.
bryson
bryson "at" hidefcowboy.com
hidefcowboy.com
Scott Coulter
on Aug 22, 2011 at 7:22:14 pm
Thanks! I'll see what works best.
I'm just jumping into CatDV, so it's been an experience.
Matthew Stamos
on Aug 22, 2011 at 7:49:21 pm
You can use the convert markers to sub clips command. This would likely make a few more sub clips but would speed up the process for longer format master clips.
