CatDV crashed when hitting save
COW Forums : Square Box CatDV
Jeanine Strock
on Aug 10, 2011 at 6:08:30 pm
I was just looking through a catalog that someone had just finished adding data. I was making corrections, hitting save as I went. I hit save and KABOOM. All the files and data were gone. There was no undo.
I looked in the Audit Log and it shows a simultaneous "publish changes" and "Delete clips" at 13:33:36.
Is there a way to find back-up files on the server somewhere?
Rolf Howarth
Re: CatDV crashed when hitting save
on Aug 10, 2011 at 6:57:15 pm
Hmm, that sounds odd, so I don't know what would have happened there. You mean the application itself crashed? Make a copy of the CatDV Error Log and backup from Home > Library > Logs (if you're on a Mac, or inside your local appdata folder on Windows). Also, please save a copy of the server log and send them all to support@squarebox.com. If you deleted clips on the server (for whatever reason) they should have been saved to the recycle bin. I'm sure the media files themselves won't have been deleted.
Jim Young
on Aug 10, 2011 at 7:32:11 pm
Rolf,
Just emailed you the log files requested to support.
-Jim
