Worker Node "No server queries defined"
COW Forums : Square Box CatDV
Martin Newsome
on Aug 3, 2011 at 10:00:13 pm
When adding a second Work set, why does CatDV Worker Node (3.1.0) grey out the Server monitor and display "No server queries defined" ?
The first work set has four actions and one Watch action.
I want to create a second to Work set to group separate workflow tasks. This new set will contain four Watch actions.
Thanks for the help.
bryson jones
Re: Worker Node "No server queries defined"
on Aug 4, 2011 at 6:21:02 am
I'm pretty sure that's the correct behavior.
If you don't create a "server query" I don't believe that will become active. There's no need for it.
If you define any Server Query, it should light up and be checked.
The three boxes correspond to the different parts of the app but if you're not using either the watcher or the server queries, you can leave them unchecked.
Check that, and report back if there's a problem.
bryson
bryson "at" hidefcowboy.com
hidefcowboy.com
