Create PDF from catalog?
COW Forums : Square Box CatDV
Jason Brown
on Jul 21, 2011 at 2:58:55 pm
I need to create an electronic version of some media to a group that needs to look through about 700 clips...with searchable metadata and proxies (I've already created).
Is there a function to send a catalog to a viewable file format like a PDF?
-Jason
Matthew Stamos
Re: Create PDF from catalog?
on Jul 21, 2011 at 5:17:11 pm
Yes load the view you want to export list grid or thumbnail and select under the edit menu print current view.
Jason Brown
on Jul 25, 2011 at 11:04:54 am
I'm about 80% of the way there...thanks for this post! :)
One more question, how can I make text larger? I'm using a modified view using poster frame and thumbnail sequence view, but notes in my text field are very small. Also, if they go too long, they get cropped. Even with a hard return in the field.
Rolf Howarth
on Jul 27, 2011 at 8:59:36 pm
Print as an HTML Formatted view, that will wrap a long Notes field onto as many lines as it takes.
Jason Brown
on Jul 28, 2011 at 2:30:15 am
Thanks Rolf...that worked perfectly.
I'm printing to PDF after outputting via HTM and the page breaks are breaking the fields into pieces.
I have 3 text fields below a filmstrip thumbnail...is there anyway to force the name-thumbnail-and 3 text fields all together and break to new page instead of breaking them apart?
-Jason
Rolf Howarth
on Jul 28, 2011 at 9:24:18 pm
There isn't I'm afraid, other than printing them out one by one. We'll make a note to look into adding an option for that however.
