re rendering and round trips
COW Forums : DaVinci Resolve
Sean Davison
on Nov 4, 2019 at 3:46:33 pm
So Im round tripping from Premier to DaVinci Resolve - 500 odd clips. Grade is done - Sent back to Premier and the client decided he wants to change the grade on just one interview.
In the old Color - FCP 7 days I would go back in to Color, find the clips and rergrade just those and render them out - Color would put a QuickTime in the original Resolve Render folder and this would replace the old clips automatically.
Is there any way to do this in Resolve?
If I render them out as clips to the render folder will Resolve overwrite the old clips?
Be nice if it did.....
Thanks Guru's
Life on the Bleedin' Cutting Edge....
http://www.1handclapping.co.uk
Marc Wielage
Re: re rendering and round trips
on Nov 6, 2019 at 5:38:21 am
[Sean Davison] "If I render them out as clips to the render folder will Resolve overwrite the old clips?"
They should. If you didn't want this, you could just highlight the newly-graded clips and only render those at the end of the session and go to a new folder or the same folder. You can check to see what is replaced by the Creation Date.
