How to grab stills?
COW Forums : DaVinci Resolve
Robert Withers
How to grab stills?
on Aug 10, 2019 at 3:04:09 am
A second try at posting this . . .
I import a film into a new project in Resolve 15 (Macbook Air, Mohave 10.14), go to the View menu to grab some stills and all the Stills actions are grayed out.
What do I need to do differently to get this function to work?
Robert
Robert Withers
Independent/personal/avant-garde cinema, New York City
Robert Withers
Re: How to grab stills?
on Aug 10, 2019 at 3:06:24 am
Oh, sorry. I see there's a Blackmagic Design and a separate Davinci Resolve forum.
Robert
Robert Withers
Glenn Sakatch
on Aug 10, 2019 at 7:58:37 pm
Stills are used to capture your color correction settings, and store them internally for other shots or projects.
You have to put them into a timeline, and then grab them from the color page.
Sounds like you want to export freeze frames?
Glenn
Robert Withers
on Aug 10, 2019 at 9:30:47 pm
Thanks, Glenn.
Yes that's what I wanted. To export still images, otherwise known as freeze frames in other software and film lingo.
I should have searched for freeze frames in the manual.
Got it done in Premiere, maybe more slowly.
Cheers,
Robert
Robert Withers
Marc Wielage
on Aug 12, 2019 at 10:40:53 am
[Robert Withers] "Yes that's what I wanted. To export still images, otherwise known as freeze frames in other software and film lingo."
I would grab stills in the Gallery -- option-command-G on the Mac -- then right click on the still and export it in whatever still format you need. Be aware you should make sure the session settings are at the same resolution as your source material.
Robert Withers
on Aug 12, 2019 at 4:51:22 pm
Thanks, Marc!
Robert Withers
Robert Withers
on Sep 22, 2019 at 10:09:13 pm
Hello all
Well, I couldn't get anything to work to make a still image, like you would make of a single frame of a movie to us as a single image, not a freeze frame to run for a certain duration. Options are grayed out in Resolve 15. Nothing under View, nothing under Clip, nothing under Gallery.
Read the fine manual.
Also tried Option-Command-G.
Nothing happens.
Guess I've got to go back and put in my 10 hours to learn the interface.
Sigh,
Robert
Robert Withers
Michael Gissing
on Sep 22, 2019 at 10:57:59 pm
Do you want just a still image from the video? If so go to the deliver page, find a frame you want to export. Mark I & O one that frame and select tiff export. That way you can mark and render multiple still frames at the full res of the footage and bake in your grade. Mark multiple frames and make a render queue. If you want you can then import those tiffs into a project to do whatever you want with them or export to Photoshop etc.
I like that Resolve doesn't require the making of a still to create a freeze.
Robert Withers
on Sep 23, 2019 at 12:36:20 am
Maybe these are controls that are only available under the Color Work Space and not under the Edit work space. Will experiment with this next time. . .
Thanks for reading, though,
Robert
Robert Withers
Michael Gissing
on Sep 23, 2019 at 7:32:16 am
Deliver page.
