Issues with rendering
COW Forums : DaVinci Resolve
Richard Lacey
on May 13, 2019 at 10:24:13 pm
I'm currently creating trancodes of ArriRaw footage to DNxHD 36 for a film.
The first four clips exported without issues.
However, every clip since has created one large file with the correct filename eg. A001C006_190513_R18X.mxf, along with 4 other files called A001C007_190513_R18X_A01.mxf, A001C007_190513_R18X_A02.mxf etc.
Each of the 4 smaller files are of identical size, but their size will vary from clip to clip.
Any idea what's happening?
Richard Lacey
Re: Issues with rendering
on May 13, 2019 at 10:40:42 pm
I realise now that these are the four sync audio channels of the clip.
This is normal behavior for DNxHD exports?
I've previously only done ProRes transcodes so this seriously freaked me out!
Tero Ahlfors
on May 14, 2019 at 3:41:30 am
You probably exported it as op-atom. If you want everything muxed in a single file try op1a.
