Switching to Timeline mode is disabled
COW Forums : DaVinci Resolve
John Vogel
on May 10, 2019 at 5:39:40 pm
It says - Please disable "timeline filter" and "show clip with handles" to be able to switch to Timeline mode.
I found the "show clip with handles" and it's not enabled. "Timeline filter"?
Can someone please explain? Not coming up in any search.
jv
Ole Kristiansen
Re: Switching to Timeline mode is disabled
on May 10, 2019 at 6:17:12 pm
Hi John
Did you google: Davinci Resolve switching to timeline mode is disabled ?
Best,
Ole
John Vogel
on May 10, 2019 at 7:48:05 pm
Thanks Ole!
I forgot to mention I was in the color section, BUT your link led me to a solution because it's all related. In Deliver, under the "File Edit Trim Timeline, etc" at the top there is "Clips". There's a long selection of choices and my sequence was under "Grouped" which I had grouped the entire sequence into 1 group to put a lut on everything. That selection needed to be on "All Clips". Once I choose that, everything freed up in Color and Delivery.
Thanks Ole!
jv
Michael Gissing
on May 11, 2019 at 3:22:48 am
The easy way to apply a grade to the whole timeline is to change from Clip to Timeline on the grade page. Grouping makes more sense to do to a smaller groups within the timeline, not the whole timeline. It works but the ability to add a grade to the whole timeline is already there.
