Can't See Masks
COW Forums : DaVinci Resolve
Cameron Dozier
Can't See Masks
on Apr 4, 2019 at 8:33:38 pm
When I place a mask, or window I guess it's called, so that I can grade a specific area, the mask wireframe doesn't show up.
I looked through the other posts regarding this topic, and the suggestions from those do not work. Clicking view and toggling Window Outline didn't work. Restarting didn't work. Wasn't really any other suggestions....
It's Davinci Resolve 15.
Thanks in advance.
Glenn Sakatch
Re: Can't See Masks
on Apr 5, 2019 at 10:21:45 pm
You also need to turn on the power window switch in your viewer window...it can be an eyedropper, or a power window...or a few other things.
Glenn
Marc Wielage
Re: Can't See Masks
on Apr 6, 2019 at 4:27:43 am
Also bring up the Power Window pallet and choose the "Power Window" tool in the Viewer window as Cameron says above.
With a BMD control surface, this should automatically happen when you choose the Power Window mode. I generally choose to only show the visible window on the GUI, because it throws some clients off, but it's a subjective call.
