I am having difficulty importing video clips into Da Vinci 15
COW Forums : DaVinci Resolve
Terence Christopher
on Mar 13, 2019 at 8:43:02 pm
I previously asked about importing M2T files into Davinci 15. After help from many users I realised that DNxHD was immensely better and started switching to that format. However that also has been impossible for me. The new clips that I have look like this Clip 001_DNxHD-HD1080[Anamorphic], however I cannot get them into Davinci. They play perfectly well. However there is something I must not be doing correctly. I have loaded Mp4 clips without a problem and also the Training videos. Could you advise me please.
George Dean
Re: I am having difficulty importing video clips into Da Vinci 15
on Mar 13, 2019 at 10:37:39 pm
Hi Terence,
Can you post the DNxHD specs (use the free app Mediainfo in text mode) here so we can take a look. Also if you have a short section you can upload, so we can download it and tinker with it, that may work well. I have no issue with Avid source in Resolve, so rather than guess, if you can provide a sample or at least the spec of you files that be be faster to a solution. Thank You.
Best Regards......George
Terence Christopher
on Mar 14, 2019 at 5:34:52 am
Here is the text mode report. I would happily sent you a clip if you could tell me where to send it.
The whole problem might be my fault as this is a new programme for me.
I really appreciate your help
Terence
General
Complete name : D:\Sony Video Archive\M2t clips clips\2006\Aug Air Show 2006\Clip 003_DNxHD-HD1080[Anamorphic].mxf
Format : MXF
Commercial name : DNxHD 220
Format version : 1.3
Format profile : OP-1a
Format settings : Closed / Complete
File size : 544 MiB
Duration : 20 s 521 ms
Overall bit rate : 223 Mb/s
Encoded date : 0-00-00 00:00:00.000
Writing application : FFmpeg OP1a Muxer 58.19.100.0.0
Video
Format : VC-3
Format version : Version 1
Format profile : HD@HQ
Format settings, wrapping mode : Frame
Codec ID : 0D01030102110100-0401020271040000
Bit rate mode : Constant
Bit rate : 220 Mb/s
Width : 1 920 pixels
Height : 1 080 pixels
Display aspect ratio : 16:9
Frame rate : 29.970 (30000/1001) FPS
Color space : YUV
Chroma subsampling : 4:2:2
Bit depth : 8 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 3.540
Stream size : 538 MiB (99%)
Audio
Format : PCM
Format settings : Little
Format settings, wrapping mode : Frame (AES)
Codec ID : 0D01030102060300
Bit rate : 2 304 kb/s
Channel(s) : 2 channels
Sampling rate : 48.0 kHz
Frame rate : 29.970 FPS (1601.6 SPF)
Bit depth : 24 bits
Stream size : 5.64 MiB (1%)
Locked : Yes
Other #1
Type : Time code
Format : MXF TC
Time code of first frame : 00:00:00:00
Time code settings : Material Package
Time code, striped : Yes
Other #2
Type : Time code
Format : MXF TC
Time code settings : Source Package
Other #3
Type : Time code
Format : SMPTE TC
Muxing mode : SDTI
Ole Kristiansen
on Mar 14, 2019 at 8:26:29 am
Hi
If you look at the picture I postet - how to use ER Media Toolkit - you forgot to change to .mov !
Best,
Ole
Terence Christopher
on Mar 15, 2019 at 6:25:12 am
Hi Ole. I am afraid the image on my computer was not big enough to see you clicking on the Mov button and as the other choice was mxf that seemed to be the right one so I just went with that. I also didn't realise the significance of the choice and actually still do not! I thought the mov format was an old low res one unrelated to HD or UHD. When is it used nowadays? I will go back and try some movies with that option. I'll report back. What had I done wrong with the format that I chose? I will go ahead and report back to the other people who are also trying to help me.
Thanks for all the very kind help
Terence
Tero Ahlfors
on Mar 15, 2019 at 6:55:35 am
It really doesn't matter if it's an .mov or an .mxf file as Resolve supports both.
Ole Kristiansen
on Mar 15, 2019 at 7:14:09 am
Yes, but there is a problem with ER Media Toolkit and .mxf - I made the test with Davinci Resolve 15 Studio - it was okay with .mov !
Ole Kristiansen
on Mar 15, 2019 at 10:25:16 am
"I also didn't realise the significance of the choice and actually still do not!"
I think there is a bug in the code that ER Media Toolkit uses to convert to .mxf extension - so davinci Resolve cannot read the files!
"I thought the mov format was an old low res one unrelated to HD or UHD."
mxf and mov is a media container and have nothing to do with low res and so on !
"When is it used nowadays?"
Everywhere ! Try asking those using MAC computer !
Marc Wielage
on Mar 14, 2019 at 12:34:00 am
[Terence Christopher] "After help from many users I realized that DNxHD was immensely better and started switching to that format. However that also has been impossible for me. The new clips that I have look like this Clip 001_DNxHD-HD1080[Anamorphic], however I cannot get them into Davinci."
How are you bringing the clips in? Are you using the Import Media command or dragging them from the desktop?
It would also help if we knew about your system: what hardware (CPU, RAM, GPU, disk i/o)? What OS? What specific version of Resolve? What timeline resolution? What resolution and aspect ratio does the format have?
Is this Resolve Studio or the free version? It may be that there are issues with using this format on the latter, particularly if it's 4K or above. I have done many sessions with DNxHD and OP1a from Avid in Resolve and it works great.
Terence Christopher
on Mar 16, 2019 at 7:15:00 pm
I am using Windows 64 bit 10 which I automatically keep updated, and Intel I 7 4770S 3.10 GHZ, RAM = 16 GB
HD= 2.0 TB DISPLAY= NVIDIA Geforce GT 750M plus Intel HD Graphics 4600 on the processor
I am limited to a Gigabit Ethernet and have only USB 2 ports on the machine. But so far they have not been a problem
My data storage is on a QNAP TVS 822T with a RAID 6 system providing 30 Tb of storage.
My original question was why I was having difficulty loading M2T video clips onto Da Vinci 15 ( free edition) but was convinced that i should use DNxHD as it made editing superior. I then changed my videos to that format, but unwittingly swamped my system storage as the files were 10 times bigger than the originals. I am trying to find a way around that impasse and have installed an 8Tb external drive which is full of my original 2.5 TB M2T videos but at least I have some space on my storage system. I have now found that I couldn't load the DNxHD files into the Da Vinci and have subsequently learned from Ole Kristansen that there is a bug in the MSX output from the otherwise superb ER Toolkit that I used to switch my videos and that I should use .mov instead. They are only 5X bigger than M2T ie 12 to 15 Tb and I am trying to sum up the energy for that. However I will be more careful just testing out one or two videos to verify that Da Vinci will handle them. It seems that Da Vinci seems to have problems with several different formats and I don't know where the problem lies.
Tero Ahlfors
on Mar 14, 2019 at 8:46:01 am
[Terence Christopher] "however I cannot get them into Davinci"
How are you not getting them in Resolve? Do they not show up in the media page? If you actually have brackets in the filename you could try removing those. Do not use any special characters when naming files.
George Dean
on Mar 15, 2019 at 4:58:10 pm
Terence@ I would happily sent you a clip if you could tell me where to send it.
When you reply there is a disc looking icon above the reply text window, that will allow you to upload a file here.
Unless the ER Media Tool Kit conversion file with the mp4 wrapper is working for you now.
Terence Christopher
on Mar 15, 2019 at 9:25:33 pm
I haven't tried that as most of my files were in M2t, and I had started to transcode them to MP4 as that is accepted by Da Vinci. However a month ago I made a huge effort and transcoded almost all of my M2T to DNxHD (however mxf) I might have to unwind them if I have lost the original.M2T. I am going to ask Ole how to do that. He said that it is possible with ER Toolkit Do you think the problem is in Da Vinci because it also doesn't accept M2t from my experience. Maybe there is some minor difference in the definitions of the standards between different editors rather than a bug?
If you want a clip to send to Da Vinci so that they can define the differences I would be happy to send it to you. However I don't want to give you this problem to solve. I will try to go to .mov . I am not up against a commercial problem as this is all done for personal pleasure and my family. I really appreciate the great generosity of so many people with their time and knowledge.
Terence
Terence Christopher
on Mar 15, 2019 at 9:12:44 pm
Well I amusing import file which switches automatically to media. The screen remains black. It is the same if I create a bin and try to import into that. However Ole has just pointed out that there is a bug in the ER emergency kit that is responsible for the problem
Thanks for your help
Terence
George Dean
on Mar 16, 2019 at 8:35:31 pm
Hi Terence,
Risking that I muck up the waters, have you tried using MediaER to convert your m2t files to h264/mp4? You can set the bit rate, deinterlace, and change the pixel ratio all at the same time, and they will run in Resolve 15 without issues.
If you want to try this, I would set MediaER to the following before dropping in a test clip.....
- Classic mode
- Video Quality = Custom, set this to match your source, I tested 25 MiB source and thereby set this to 25,000.
- Audio Bit Rate - I left this at 96 Kbps, but you can change this to match your source.
- Media Container = MP4, although other option should also work.
- Force Size To should be checked and set the drop down to 1080p HD
- Replace Audio should be unchecked
- Extract Audio To Wav should be unchecked
- Anamorphic should be checked
- Deinterlace should be checked
- The remainder settings can be left at default
Then drag your test clip and convert.
The test I made for this was an old m2t clip from my Canon XL2 1440x1080, 29.970, interlaced, bite rate 25.3 Mb/s, file size 23.3 MB. The resulting conversion file was 1920x1080, 29.970, progressive, bite rate 27.5 Mb/s, file size 23.3 MB. Both were 4:2:0 8 bit.
I prefer using DNx or ProRes, and when I was using source from this camera, I converted all the source to DNx intermediate, which was overkill in size and quality (which wasn't used), but at the time the DNx ran smoother on the NLE and PC I was using. However I did not have storage space issues with the projects at that time.
The conversion I list above, should keep the quality pretty much the same, hold the file size down, and as you already know, using Media ER Tool Kit is very easy, supports batch processing, and relatively fast. Just a suggestion that may fit your needs.
BTW: I forgot to add this, the m2t file I used for testing from the Canon XL2, was easily added into Resolve 15.3 without converting.
Terence Christopher
on Mar 16, 2019 at 10:52:54 pm
Thanks George for all of your help. I will send my clip to you after replying to your latest note. I had been thinking of changing to mp4 but was convinced by Ole and others that it would be better to go to a codec (If that is the right word) which would allow better quality processing by Da Vinci. I was told that MP4 is again over compressed. and is a delivery codec. It seems that the .mov format with DNxHD may be half of the size of DnxHD which I may be able to handle and a friend advised me that a PNG compression is lossless so I was wondering whether if after I have edited the video that I might save it as Mp4 .PNG and completely discard the DNxHD.mov I don't know what the best way to save the clips would be nor if they would ever be of use to anyone.If I saved the original as MP4 as you suggest. Would that be a good storage medium for the clips? I would like to stream these videos if possible (for remote family) but I am limited by the ridiculous bandwith of Comcast upload and their gouging. I would appreciate your advice as I am a complete novice but admire beautiful images.
Terence
Terence Christopher
on Mar 16, 2019 at 11:11:39 pm
Terence
addendum I have been attempting to upload but even the smallest clip exceeds the limits imposed by Cow. 15 seconds comes out as 1/2 Gig
George Dean
on Mar 16, 2019 at 11:44:17 pm
Terence, 1st please don't read into my suggestion that I disagree with Ole to use DNx, as I stated I would prefer DNx over most h264/mp4 files. I was just adding a suggestion to reduce the size of your converted files to save storage space. However, if you use the 36Mb option in DNxER, the files size is only about twice the size of your original m2t (or at least mine) and the bit rate is a bit higher than the h264 I listed above.
The issue, as I see it for the most part (not completely) is finding a bit rate in the codec that retains enough quality for your working files and only takes up a reasonable amount of extra storage space. However, a h264/mp4 file can be a working or delivery, mostly depending on the bit rate selected. All of which most likely will not have a bearing on what you need.
If your m2t files have let's say a bit rate of 40 Mb/s, transcoding/converting it to DNxHD 185 is going to be a waste, because you are starting with 40 and it will never be 185 by converting. Pretty much what happens is the files size gets bigger and on some systems the DNxHD will play back smoother than a lower bit rate (compressed) h264. h264 is actually capable of being lossless, but then it would require huge amounts of storage space with no benefits of increased quality.
However h264/mov would be a good candidate for a delivery format for streaming to your family, selecting a bit rate that retains reasonable quality, hold the files size down for saving bandwidth, and will play in all the devices your family members have available.
I'm not familiar with mp4/png, but when you included the word lossless, that to me spells huge storage space requirements! And, I don't think Resolve will render it, maybe I'm wrong.
If your sample file was .5 Gb, I would not be able to download it anyway, as I'm on a limited monthly data program, I was kinda thinking a short sample would be more like 100 Mb.
I'm getting confused about your m2t source files, have you posted a Mediainfo (in text mode) report as yet? When I post this message I will run back through your post see. I don't understand why a 15 second clip would be 500 Mb.
George Dean
on Mar 16, 2019 at 11:47:29 pm
Hi Terence,
Looking through your post I only find the Mediainfo report of the mxf converted file. Can you post a Mediainfo report on your m2t file? I would like to compare it to mine to see what difference there is, as my m2t's load into Resolve without problems, as well as, I'm curious about the bit rate. Thank You.
Robert Withers
on Mar 19, 2019 at 5:40:08 pm
Codecs and containers -- they're different. .mov and .mp4 are containers. Codecs live inside of containers. I have to look these up every time. I think h264 is a codec that can live in a .mov or .mp4. ProRes is an HD mezzanine codec that can run inside a .mov container. You can look up these things--I do over and over.
Cheers,
Robert
Robert Withers
Independent/personal/avant-garde cinema, New York City
Terence Christopher
on Mar 20, 2019 at 1:06:46 am
Thanks for this help and advice. I have just been testing Ole' s suggestion which was to use DNxHD.mov it didn't reduce the file size but gave a beautiful coloration of waves stirring up the sand with a lot of texture of the colour. Is that only available with bigger formats or if compressed to MP4 will it still be visible? If I need to stay with the bigger format during editing, maybe I should invest in more disk space?? and in the interim have several 8 TB USB drives holding the masters. These videos were taken on a camera I am no longer using, having switched to a Panasonic 4K which I am using at this time. Everyone told me that I should capture the data directly as DNxHR which is thus hanging over me. I cannot think what storage space I will need. I thought 60 Tb in a RAID configuration was overreaching but it is evidently insufficient. It seems that perhaps having it all in RAID is unneccessary though. Is there any risk of deterioration (apart from fire and magnetic pulses from some A bomb ) from having the masters on 8 TB USB drives?
Terence
George Dean
on Mar 20, 2019 at 3:31:07 pm
Hi Terence,
I think huge files is what we deal with dependent on how we will deliver the end results in the future. I'm not sure how I will deliver in the future, so I suffer with storage space, acquiring video in the highest quality chroma subsample and color space as my camera is capable of, and that happens to be for me, HDxHR 422 10 bits. Most of the stuff I produce goes to 1080p 420 8 bit, but I keep my master material at HDxHR 422 10 bits, so if in the future I produce 4K HDR, I can possibly use some of my past recorded materials.
But, I'm a small potatoes guy, retired and only do this as a hobby. I'm serious about it, nonetheless I'm not in the business and at 73 there are not a lot of years in the future for me.
I think the best way for you to determine if a lessor codec, to save storage space, such as h264/x264 (or maybe h265) would work for you is to try it out and see the difference in both comparison to your source, and in comparison to your delivery format. h264 can produce higher quality than that which is normally used for delivery, by increasing the bit rate, but by doing that, it also increases the size of the files. It will however never be better than your source and how much quality loss can be tolerated, is up to you.
As for your other question, as you know, drives can (and do) go bad. How much redundant storage we keep is pretty much dependent on the budget. I approach is, if it is important enough to keep for the future, it is important enough to use the safest method I can afford. Your mileage may differ.
Terence Christopher
on Mar 20, 2019 at 5:16:14 pm
HI Thanks for your reply. I am in the same boat except a bit older but with the similar ideas. My purpose has been to leave a good record of family life for my grandchildren. I guess my appreciation of the beauty of an image forces me into getting the best quality rather than than just what is is necessary. That is why I switched to HD back in 2006 and UHD in 2015 when reasonably priced reliable equipment became available. I am forking out for data centre quality HD with 5 year warranties which I hope will give longer trouble free service for everyone plus a commercial quality RAID 6 NAS which should give prediction of disc failure (I hope) However I am thinking that this is more useful for the final product and perhaps storing the larger masters on large standard USB drives would suffice for the back up. (Just in case anyone wants to re edit the data.) My son in law said that PNG is a lossless compression which he uses and says that it works for videos too, I looked it up and there was a reference to that though it is not as small as MP4. Streaming would be nice for family members though I would not like to sacrifice the quality for that.
I will do as you recommend and will play around before deciding. However I do not know what bit rate I should select for HD and UHD what do you use? Could you tell me how many Terabytes you use for your system especially for UHD and is all of that with reduntant RAiD support
Thanks for your guidance
Terence
George Dean
on Mar 20, 2019 at 9:05:07 pm
Hi Terence,
Long story that I will not bore you with, so my current storage is in USB drives of various sizes. I no longer have an NAS or RAID, although I will need to invest in an NAS probably sometime later this year. Not having any recent experience with NAS/RAID, I knowledge on the setups and cost is based on 12 year old technology, so I will op for others that have current systems to hopefully provide you with some real reference.
Terence Christopher
on Mar 20, 2019 at 9:32:31 pm
Well I have too many USB drives lying around all without the size needed to handle this quantity of data. That has contributed to my problem as I have now been organising some 50,000 photos not including pre digital as well as various types of video and film going all the way back to 8.mm I thought that a 6 bay NAS with 6X !0 Terabyte hard drives would be adequate. That gave me 30 Tb but my 3 Terabytes of m2t overwhelmed that and I now have an * 8Terabyt USB drive that is also full. My Nas has the capability to switch to apple and a thunderbolt drive if necessary or a 10 gigabit/sec Ethernet, however I am doing OK with the old standard 1.0 Gigabit/sec so far. But I am not sharing.
If I need to double my NAS size I will be forced to purchase a satellite NAS which can be configured to add on. I did not want to purchase 10 Tb drives as they are expensive but had opted for the 6 bay system which was a mistake as I now find.
Terence
